Electric Choke Grounding
Old 10-07-2013, 11:52 AM
mark79,80
mark79,80's Avatar
Default Electric Choke Grounding
I recently installed an electric choke in a 1979 L82 Rochester carburetor replacing the hot air choke.
I removed the electric choke from a 1980 L48 carburetor and noticed that
the end of the choke coil is isolated from grounding as the carburetor
has a rubber tube covering the choke linkage. On the 1979 carburetor
the end of the electric choke coil fits between a metal tab with slots so it is not isolated.
The electric choke seems to function correctly.
But the GM engineers must have had a reason isolating the end of the choke coil from grounding.
Is there a problem the way I have installed the choke?
Old 10-08-2013, 10:56 AM
MelWff
MelWff's Avatar
Received 1,806 Likes on 1,597 Posts
Are you sure the coil is actually in the circuit? I was under the impression that there is a heating element that the coil is attached to. The rubber may be there for some other purpose such as vibration.
Old 10-08-2013, 01:24 PM
mark79,80
mark79,80's Avatar
Coil works. Energize coil and choke fully opens.
Old 10-08-2013, 02:02 PM
MelWff
MelWff's Avatar
Yes I understand the coil works, you are assuming the spring is part of the circuit, isnt the spring mounted on a heating element? The ground appears to be through the housing not the coil.
http://www.cliffshighperformance.com...lectric_1.html
Old 10-08-2013, 08:11 PM
'75
'75's Avatar
Old 10-08-2013, 08:52 PM
mark79,80
mark79,80's Avatar
Thanks for the reply. I thought the choke coil was the heating element.
To Electric Choke Grounding
Quick Reply: Electric Choke Grounding
