Right side door inside trim
Old 10-06-2013, 07:30 AM
Ryder12
Ryder12's Avatar
Default Right side door inside trim
I have a 1977 and when you open the passenger door there is a metal strip red like the interior screwed with 3 screws to the inside trim. The problem I have is that 2 of the small brass cylinders that the screws for the metal trim screws into have come out of the inside trim holes. I tried to glue them back with epoxy but didn't hold. Any suggestions ??
Old 10-06-2013, 08:18 AM
sug
Support Corvetteforum!
sug's Avatar
2020 Corvette of the Year Finalist (stock)
C3 of Year Winner (stock) 2019
Hi ryder12 you could ditch the brass parts and fill with epoxy then drill to suit screws till you can replace the rear panels you could try super glue for the brass parts Loctite make a few different ones for metal ,rubber,plastic etc
Old 10-06-2013, 02:26 PM
Ryder12
Ryder12's Avatar
Old 10-06-2013, 03:23 PM
'75
'75's Avatar
http://www.zip-corvette.com/ProductD...L2-SR&CTitle=&
Old 10-06-2013, 04:24 PM
Ryder12
Ryder12's Avatar
Thanks just placed the order
To Right side door inside trim
Quick Reply: Right side door inside trim
