Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 10-02-2013, 03:21 PM   #1
zuendler
CF Senior Member
zuendler's Avatar
Default zz502 killed my M21 Muncie
Click the image to open in full size.
Is this something I had to expect? I was shifting with 2/3 throttle, from 2nd to 3rd. I was a bit late on the clutch, means I pushed the stick a bit while clutch was not fully released. Then something broke inside...
What now? Engine has ~ 550ft/lb.
All normal Keisler tranys are rated to 500ft/lb,
except the TKO600 and SS700
zuendler is online now   Reply With Quote
Old 10-02-2013, 03:28 PM   #2
v2racing
CF Senior Member
v2racing's Avatar
The M21 helical gears are designed to run quiet. Straight cut gears like the M22 are much stronger but whine. The M21 wasn't designed for performance 500" engines.
__________________
75 Roadster, 406", Ported Brodix -10 Heads, 225cc, 2.100"/1.600" valves, 11.8 to 1, Ross Ultralight Pistons, Custom Solid Roller, 650/609 lift 248/252 dur 110 LSA, Comp 1.6 in./1.5 ex. Extreme Gold Rockers, 7/16 Studs, Stud Girdle, Ported Victor Jr., Modded 750 Holley, Jet Hot Coated Hooker Super Comp Headers, 3" Mandrel Bent X Pipe Exhaust with 2 Chamber Mufflers, Art Carr 700R4, 3500 stall lock-up, Super Ten 4.11 posi, 265/40/18 F1, 285/40/18 F1 Goodyears, chrome 5 spoke Vision Legacy Wheels.
v2racing is offline   Reply With Quote
Old 10-02-2013, 04:46 PM   #3
zuendler
CF Senior Member
zuendler's Avatar
I have to find out if the SS700 can be delivered without waiting 6 months now. And if it can be put in place without removing the cross member and to do it all in my garage, without a car lift.
Any experiences?
I thought also about just restoring the M21 - but I think thats no option, because it will break again.
Old 10-02-2013, 04:50 PM   #4
MelWff
CF Senior Member
MelWff's Avatar
contact a company similar to this to upgrade the transmission
http://www.riversidegear.com/muncie-4-speed/
MelWff is online now   Reply With Quote
Old 10-02-2013, 05:00 PM   #5
Garys 68
CF Senior Member
If you stay with a Muncie, Autogear offers a lot of upgrades.
Garys 68 is online now   Reply With Quote
Old 10-02-2013, 05:19 PM   #6
zuendler
CF Senior Member
zuendler's Avatar
wow, Keisler is responding within seconds! They cant give any delivery date for new orders on the SS700. So this option is out.
I won´t stay with the Muncie, because I want an overdrive gear.
So only the TKO 600 is left.
Old 10-02-2013, 06:07 PM   #7
Super6
CF Senior Member
Super6's Avatar
I am easy on my clutch, but take my 550 ft-lb 468 to 6500 and shift quick. TKO600 has been fine with that. My Vette-brother runs 501 RWT with TKO600 and no problems for 2 years. like me, he is also not a clutch-popper.
Super6 is offline   Reply With Quote
Old 10-02-2013, 06:11 PM   #8
Tjf2000
CF Member
Give the folks at hurst driveline a call for a TKO600.
Tjf2000 is offline   Reply With Quote
Old 10-02-2013, 06:18 PM   #9
Super6
CF Senior Member
Super6's Avatar
RayY on CF runs a 555ci engine with 3.73 and TKO600. I believe he has had that combination for a year or 2. Just recently, he confirmed that it was working fine on a thread here.
I am a few weeks away from running a 540 through my TKO600. With my driving style, I think it will be fine. Obviously, that's not evidence.
Old 10-02-2013, 07:02 PM   #10
roscobbc
CF Senior Member
roscobbc's Avatar
M21 + 3.08 rear end + 285/40/18 Toyos + 565 ft/lbs - 4 years in the car and Muncie is holding-up fine so far (unlike stock engine mounts)
roscobbc is offline   Reply With Quote
Old 10-02-2013, 07:18 PM   #11
Solid LT1
CF Senior Member
Solid LT1's Avatar
Quote:
M-20/21 gears are cut at a 45 degree angle, the M-22 gearset is 22.5 degrees, I find the sound of an M-22 less offensive than a ZF 6 speed in a C4 Corvette myself. Autogear has M-22 style gears in both traditional "close ratio M-21" and "wide ratio M-20" gear ratios, either set would handle that power, you should also investigate using the Autogear "super case" reinforced Muncie main case and iron mid plate.
Solid LT1 is offline   Reply With Quote
Old 10-02-2013, 07:53 PM   #12
tektrans
CF Senior Member
tektrans's Avatar
Trans had it comin'
tektrans is offline   Reply With Quote
Old 10-02-2013, 08:55 PM   #13
TimAT
CF Senior Member
TimAT's Avatar
Autogear also has a gearset that makes 4th an OD.
http://www.autogear.net/pdf/HighPer_..._sheet_t10.pdf
TimAT is offline   Reply With Quote
Old 10-02-2013, 09:30 PM   #14
GRIZ73
CF Senior Member
GRIZ73's Avatar
Default Zz502 killed my Muncie
I have a rebuilt Muncie with a gear vendors overdrive behind my 496 full roller that dynoed at 635 hp . Very solid very strong and overdrive in any gear plus one clutch-less shift. Rebuilt Muncie $500 GVO $3,000 installation $ 1,500 ? Not too bad. Check out GVO they are even warranted for drag racing.
My $.02
GRIZ73 is offline   Reply With Quote
Old 10-03-2013, 01:24 PM   #15
SteveG75
CF Senior Member
SteveG75's Avatar
T-56 Magnum behind my 496 BBC. 700 ft lb rating, 5th and 6th overdrive.
Quicktime has a conversion bellhousing for the LS spec transmission behind a traditional Chevy engine. Hurst Driveline had a modified QT bellhousing and the parts (throwout bearing sleeve) to allow a mechanical clutch linkage. Had to modify the crossmember (used a BowTie Overdrives T56 unit with slight mods), 1310 billet yoke with removable caps, and custom driveshaft. Used a 73-81 T56 Camaro shifter, rotated the stick part 180 degrees and it fit the stock console perfectly (already had a large center hole from earlier Tremec 3550 swap).
I have the version with 2.66 first and .8/.62 overdrive. Works great with my 3.73 12 bolt rear.
More info on the Hurst parts here:
http://www.chevelles.com/forums/showthread.php?t=325170
SteveG75 is offline   Reply With Quote
Old 10-03-2013, 02:58 PM   #16
Belgian1979vette
CF Senior Member
Belgian1979vette's Avatar
Shockloads will kill any trans sooner or later.
Belgian1979vette is offline   Reply With Quote
Old 10-04-2013, 01:16 PM   #17
Shark Racer
CF Senior Member
Support Corvetteforum!
Shark Racer's Avatar
Send a message via ICQ to Shark Racer Send a message via AIM to Shark Racer
Owning a TKO600, if I could do it all over again I'd go with a T56.
Shark Racer is offline   Reply With Quote
Old 10-04-2013, 01:55 PM   #18
flyeri
CF Senior Member
flyeri's Avatar
I have the TKO600 behind a 468 with a 3.55 rear end and 27in tire height. It will lug along at 1400-1500 rpms and 50mph and is extremely happy in the 1900-2100, 65-70 mph range. I can see where some would want an OD gear that is more in the .75 ratio bur for a driver like mine is the .64 is great.
flyeri is offline   Reply With Quote
Old 10-04-2013, 05:02 PM   #19
Super6
CF Senior Member
Super6's Avatar
Quote:
Why the T56? 6th gear? Torque capacity? What is the torque capacity?
Didn't consider it because I didn't like the idea of messing with the fiberglass and console or the welded up offset shifter. So I bought the TKO. And then immediately got the sawzall out and cut up my crossmember. LOL.
Old 10-05-2013, 12:00 AM   #20
Shark Racer
CF Senior Member
I have a 78 which originally came with an auto, so I had to cut the floorboard regardless. I ran a hydraulic clutch release assembly. Soooo, I pretty much did everything I would have had to to do install a T56.
That said, the T56 shifts better, does have the extra gear and would have come in at the same price or possibly lower. Speedometer output would have been an issue, but not unsolvable.
The lower geared T56 (like in a GTO) would have probably been the better choice for my personal setup. As for torque capacity, 400lb-ft +, depends on the source application. A T56 magnum comes in at 700LB-FT.
Reload this Page zz502 killed my M21 Munci
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
