Found a 68 L79 where it did not belong, what now?
I bought a 350 badged 69 Camaro Convertible form a relative. She has had it since 1974. She thought the motor was original. I looked into it, and I have learned it is an L79 from a 68 vette. Here are the pics to the castings and engine stamp. http://www.camaros.net/forums/album.php?albumid=1481
Partial VIN = 18S415780
Engine Code = V0325HT
Engine Block Casting - 3914678
Cylinder Head Casting - 3917291 / C 19 8.
The person who did the engine swap did not take the vette's intake or carb, so this is an L79 with 69 Camaro 350 2 barrel intake (3916313) and a 2 barrel Rochester carb. I think this was done due to fact the L79 was for a manual and the Camaro is an auto (kickdown issue, pedal linkage, etc.)
I was leaning toward leaving the motor in the Camaro and bringing this L79 back up to snuff with the right intake and a 4 barrel carburetor. My question is what parts do I need to do that? I have a 4 barrel 1969 Camaro Qjet. I assume I need an intake with casting 3927184 and I need to check the exhaust manifolds for 3932461 (Left) and 3872765 (right). (The car is currently dual exhaust.) I would then need 327 valve covers from a Vette and the air cleaner from a 327 vette. Do you agree with the casting numbers I listed? Are there others? Would there be any difference in the distributor? Am I missing anything?
A member of camaros.net also suggested I see if this if someone had the matching car or needed the L79 motor. Therefore, I may post this in the classifieds, but thought I would see if this matched anyone's car here.
Just not really sure what to do with it at this point, but it is being under-utilized with the wrong intake and carb. I also only have monoleaf springs in the back with a 10 bolt rear end and drum all the way around. This may just not be the right motor for this car.
Regardless, please let me know if I have the parts right and whether I am missing anything, so I can start looking for parts.
Thanks for the help
Thanks for the help
Swap the intake and carb. Unless you're wanting to do more, no need to swap anything else. You will need a 4bbl air cleaner too.
There are a bushel basket full of aftermarket intakes out there that will perform equal to or better than the stock L79 intake.
While not totally consistent, my goal is to have a stock, period correct 1968 L79 motor in my existing stock, otherwise period correct 1969 Camaro, so I am trying to avoid aftermarket. My goal is to get the right casting numbers/part descriptions for what I need then go to the WTB board and post requests.
Can someone confirm the casting numbers for the intake and exhaust manifolds? It seems all I need otherwise are the valve covers and an air cleaner.
Eventually I will have to deal with the fact I only have a 3 speed T350 transmission mated to the L79 motor.
Thanks.
Thanks.
Thanks.
Thanks.
