One Pc Oil pan gasket and timing cover
Old 09-29-2013, 12:25 PM
Dan H.
Dan H.'s Avatar
St. Jude Donor '17
Default One Pc Oil pan gasket and timing cover
I have the felpro one pc oil pan gasket. I also got the felpro timing cover gasket set. When I started my car for the 20 minute break in, I had a substantial oil leak at the front of the oil pan. Probably about 1/2 a quart over 20 minutes.
My question is do I use both the black gasket that came with the timing cover gasket kit AND the one pc oil pan gasket? Seems like the one pc gasket should seal this up alone, but I'm not sure if I'm overlooking something here? I'd like the second attempt here to cure the leak.
Old 09-29-2013, 12:53 PM
Roco71
Roco71's Avatar
I know that I did not. What year is your car? 75 and newer use a different oil pan and the front seal is a different size.
Old 09-29-2013, 01:05 PM
7T1vette
7T1vette's Avatar
Received 2,715 Likes on 2,273 Posts
It appears that you allowed the black RTV to completely set-up before installing the pan. That could cause you a problem, if there is a bit too much RTV in those corners.
Best way to do that is to just let the RTV get a bit tacky, then put the pan in place and put bolts in and just snug them down a bit. THEN you let the RTV set up and, finally, torque the bolts.
If you have excess RTV in those joints, it could cause the pan to warp.
Old 09-29-2013, 01:48 PM
Dan H.
Dan H.'s Avatar
St. Jude Donor '17
My car is a 71
The pic actually shows my second attempt. In the middle of the job I had to leave for the emergency room. Have a new gasket delivering this week to take another crack at it.
In my first attempt, I did not RTV the corners thoroughly. I think this also helped the oil leak.
Old 09-29-2013, 01:57 PM
Roco71
Roco71's Avatar
Make sure that the corners are clean and there are no traces of the old gasket.
7T1vette
7T1vette's Avatar
The "emergency room" doesn't sound good...
Good luck on the second attempt. I don't think you needed to buy another one-piece gasket....just clean off the RTV and use it again. Unless it was damaged, it should last for many removals.
Old 09-29-2013, 02:17 PM
Dan H.
Dan H.'s Avatar
St. Jude Donor '17
How do I remove the old dried up RTV?
Old 09-29-2013, 03:13 PM
Roco71
Roco71's Avatar
I would think that it would just peel off.
Old 09-29-2013, 05:50 PM
7T1vette
7T1vette's Avatar
Old 09-29-2013, 06:24 PM
TimAT
TimAT's Avatar
Wipe the areas you're going to put the RTV down really well with alcohol. RTV won't stick if there's any trace of oil.
Old 09-29-2013, 08:24 PM
George Ries
George Ries's Avatar
Did you use felpro 1880
Old 09-29-2013, 08:27 PM
George Ries
Do not use the black rubber that came with your timing cover set
Old 09-29-2013, 09:41 PM
Dan H.
Dan H.'s Avatar
St. Jude Donor '17
Thank you!
Kinda what I thought, but there have been several times where my instincts have been wrong
Old 09-29-2013, 09:48 PM
Dan H.
Dan H.'s Avatar
St. Jude Donor '17
I used 1885, it claims gen 1 small block 350 1955-1974. Also says "Thin Front Seal"
1880 states "Thick Front Seal" covering years 1975-1979 gen 1 small blocks.
My car is a 71 LT-1
Am I using the wrong one and don't realize it?
Old 09-30-2013, 08:40 AM
77C34SPD
77C34SPD's Avatar
My car is a 71 LT-1
That depends, are you using the original oilpan?
Old 09-30-2013, 08:46 PM
George Ries
My car is a 71 LT-1
it shouldnt have leaked at all i have used the 1880 on 68 oil pans its a little tight but will go on
Old 09-30-2013, 08:51 PM
George Ries
My car is a 71 LT-1
you may have to use longer bolts to get it started and then once its on replace with the old bolts one at a time
Old 10-01-2013, 06:05 PM
Dan H.
Dan H.'s Avatar
St. Jude Donor '17
George,
Thank you for your response. I stopped at auto zone on my way home tonight and picked up an 1880. It lays on the pan nicely and I think it'll fit better. Some night this week I'll get it on there.
I knew the pan wasn't original, it's a 6 qt gm pan though. I just didn't think about it being different.
To One Pc Oil pan gasket and timing cover
Quick Reply: One Pc Oil pan gasket and timing cover
