Dome light timer 1977 corvette
Old 09-25-2013, 06:56 AM
Ryder12
Ryder12's Avatar
Default Dome light timer 1977 corvette
It Appears that I will not be able to find a replacement for my 1977 dome light timer. Does anyone know how to jump past the old timer.
Old 09-26-2013, 05:24 AM
nz corvette
nz corvette's Avatar
Hi, yep lift the dash pad on a warm day and unplug the dimmer relay(round alloy cylinder) above tacho and connect the 2 plugs left over
cheers Dave
Old 09-26-2013, 06:52 AM
Ryder12
Ryder12's Avatar
On a 1977 it is not a round cylinder it is a black plastic box with orange white and a blue wire. 77 is the only year they used this relay.
thanks
Old 09-26-2013, 04:18 PM
nz corvette
thanks
Hi, may be on your 77 but my early model it's a round cylinder relay, they did change quite a bit from early 77 to the later models in the same year!
Old 09-27-2013, 06:44 AM
Ryder12
Ryder12's Avatar
Old 09-27-2013, 05:22 PM
MacVette86
MacVette86's Avatar
If it's the square relay, you jump the two white wires where the relay plugs in.
Old 09-28-2013, 06:28 AM
Ryder12
Ryder12's Avatar
To Dome light timer 1977 corvette
Quick Reply: Dome light timer 1977 corvette
