Wierd plug
Old 09-20-2013, 11:55 AM
bemfeito
bemfeito's Avatar
Default mysterious plug
Good morning and happy Friday.
Quick question, I had to open the center console in order to fix the cigarette lighter(which I did), upon opening I found this plug unconnected and can't seem to figure out where it goes.
Please gurus of knowledge, help a curious corvette owner out of his curiosity.
(corvette books haven't arrived yet)
c3 1975
Old 09-20-2013, 06:34 PM
jnealg
jnealg's Avatar
Do you have an aftermarket or nonstock radio?
Old 09-20-2013, 06:52 PM
jnb5101
jnb5101's Avatar
automatic trans bu and starter safety connection?
Old 09-22-2013, 06:15 PM
bemfeito
bemfeito's Avatar
Thank you very much, I appreciate all the help.
The radio is original, also it could be the automatic trans, but there are already wires leading to there, and no space available that I can see it could be connected to.
I will be taking off the gauges dash soon, since I need to replace the lamp for the clock and fix the clock ( its not moving). Maybe this plug goes behind that dash.
Thanks for all the help
Old 09-23-2013, 07:39 AM
LudemJo
LudemJo's Avatar
I am quite certain that it is the seatbelt connection going to the warning light and/or the interlock that prevents the car from starting unless the seatbelts are fastened. Mine is disconnected as well. I found the info in the AIM. I replaced my seatbelts with non-wired units, so I felt no compelling desire to hook the connections back together,,,why make trouble for yourself.
John
Old 09-23-2013, 10:20 AM
bemfeito
bemfeito's Avatar
Wow, I was unaware that feature existed. I will most certainly not connect it. The buzzer was already annoying enough, I disconnected it. Thank you so much LudemJo.
Yesterday I removed the gauge panel to look for a place to connect such plug, I had no luck. I was clearly looking on the wrong place.
Old 09-23-2013, 10:30 AM
MelWff
MelWff's Avatar
Received 1,807 Likes on 1,598 Posts
Default Seatbelt interlock
John
The interlock system you are referring to was only one year and that was 1974.
Old 09-23-2013, 11:03 AM
bemfeito
bemfeito's Avatar
ok... i guess i'll wait for my wiring diagram to arrive
Old 09-23-2013, 04:16 PM
bemfeito
bemfeito's Avatar
Diagram arrived, can't find it.
I looked at the seat belt ( removed the hand-brake console), there are only two wires there and they are going to the seat belt. They are black and white, and they connect to the seat buckle. On the wiring diagram I cant find the purple/yellow wire.
I am lost.
Old 09-23-2013, 04:24 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
What model year?
Old 09-23-2013, 04:27 PM
MelWff
MelWff's Avatar
first post says 1975
Old 09-23-2013, 04:29 PM
bemfeito
bemfeito's Avatar
1975 automatic
Old 09-23-2013, 05:25 PM
Peterbuilt
Peterbuilt's Avatar
Received 1,244 Likes on 965 Posts
Default Here's your diagram.
All 74's and some early 75 have the seat belt interlock.
Old 09-23-2013, 07:51 PM
bemfeito
bemfeito's Avatar
I have opened the console again, and inspected it further. Basically, the plug is only two prong, with each prong having two wires going in to it.
The two wires, pink and pink/white comes from the gear lever. They each go to their own prong. From the prong the pink wire remains pink and goes to darkness. The other (pink/white) becomes purple/yellow and merges with the purple wire.
[IMG][/IMG]
I guess it will remain a mystery, if it is the interlock sytem I am missing a lot of stuff.
[IMG][/IMG]
Old 09-23-2013, 08:01 PM
Duane4238
Duane4238's Avatar
Maybe it's for the optional flux capacitor!
Duane
Old 09-23-2013, 08:06 PM
bemfeito
bemfeito's Avatar
found one on ebay, I knew I was missing something, I'll be ordering it now. haha
To Wierd plug
Quick Reply: Wierd plug
