Sag in drivers side rear of car
So my 68 has a noticeable sag from one side of car to the other when looking at from the rear. One of my friends is suggesting it could be a rear enlightenment issue, Is that possible? And what should I be looking at if it is?
There's a number of possibilities that can be found with a search. One overlooked one that I always suggest is check the sways bars for even tension side to side. Even the front sway bar can affect the rear heights.
On mine I found two issues that pretty much fixed the rear driver side lean. When I replaced the front a-arm bushings I found that the front right spring was not seated all the way down in its seat. While this didn't seem so obvious on the right front it pushed the left rear down. Also I found that the front sway bar has a twist that when the links were tightened down pushed the right front up a bit and the left rear down.
Received 1,137 Likes
Have the same problem. Mounts are good, frame is straight, sway bars are not preloaded. I am wondering if it is worth flipping my fiberglass spring 180? It is about 20 years old but no signs of delamination or stress.
Okay i have included a picture of the rear of my car to show the sag.
I had it on the hoist today and tried some adjustments and everything seems to be fine with the suspension.
I measured from the rear wheel wells and both sides are the same measurements to the pavement, the drop seems to be more in the tail of car,the drivers side extreme rear. Also measured the front wheel wells and the measurement is only off a 1/2 inch from the drivers to the passenger side, being lower on the passengers side.
Now if it was the a rear body mount, Would it be the one behind the rear wheel? And if so what do i need to do to check?
Received 2,878 Likes
Hi nb,
Yes, you should take a look at the #4 mount, the one behind the rear wheel.
You'll want to be looking to see that the mount itself isn't too rusty and also check the condition of the aluminum 'puck' that's used as a spacer. The 'pucks' can deteriorate over the years and collapse because of oxidation.
Take a peek. Hopefully it'll be o.k. and eliminate one possibility.
Regards,
Alan
Regards,
Alan
Hi nb,
Regards,
Alan
Regards,
Alan
Hi nb,
There was a change to the rubber body mount in 1973.
You CAN change to the rubber type but if you do you should probably change ALL of them. There's a slight difference in the thickness between the aluminum and rubber mounts.
You MAY be able to raise (pry) the body up enough to get the puck out... it depends car to car.
You should try to determine first if it needs replacing at this point.
Regards,
Alan
Regards,
Alan
My 80 used to sit a bit low on the drivers seat. When I changed out the leaf spring bushings, I was happy to see a side benefit of the car coming back to near level after the install. Just something else to check.
Well I looked at the body mounts today, And they look nearly new,like they have been replaced not too far in the past.And they are aluminum bushings.Nothing wrong with them at all.
I don't know if I am disappointed or happy about it.At least if the it was the body mounts,I would know what to fix.
