Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 09-15-2013, 08:44 AM   #1
rgpta
CF Member
Support Corvetteforum!
Default 76 Front Fenders alignment
I had body mounts replaced and noticed there is a gap on the upper portion of doors and left fender is only inch or so above tire. Can someone provide instructions how to adjust the fenders?
The center I took the car to said that is the way the car was, but I know it wasn't. so basically I'm on my own to fix.
rgpta is offline   Reply With Quote
Old 09-15-2013, 06:03 PM   #2
DUB
CF Senior Member
Your description of the area needing adjusting is not making sense. Post a photo...and when you do so...do not do it so close that I can not see what it looks like from a distance. If you have to apply a colored tape to the area in question...do so...so i can see what you are seeing.
DUB
DUB is offline   Reply With Quote
Old 09-16-2013, 04:48 AM   #3
Belgian1979vette
CF Senior Member
Belgian1979vette's Avatar
The gap between the doors and fender in that location is something which is normal on the cars.
An inch of free space between the tire and the fender is small.
The bodymounts need to be shimmed from the frame according to the original factory shim stack. So check that first.
If that's ok, then look at the connection of the radiator support to the front frame.
Belgian1979vette is offline   Reply With Quote
Old 10-03-2013, 06:51 PM   #4
rgpta
CF Member
Default Pictures
Here is what it looks like
Reload this Page 76 Front Fenders alignment
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Fender liner has a huge gap where it's supposed to mate to the fender 914eener C7 General Discussion 4 06-19-2014 10:07 PM
need driver front fender c6 greasemonkey07 C6 Parts for Sale/Wanted 0 06-03-2014 04:39 PM
Rear tires rub the inner fender?? rabrooks C6 Z06 Discussion 32 06-08-2013 10:23 PM
Cracked rear fender mulalleybs C5 General 6 01-17-2013 09:57 PM
(Sep 2012) Fender hitting the door slightly?? check the middle screw alignment....... SteveDotenMotorsports C5 Tech 0 09-23-2012 12:01 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
