Fender / Fender Skirt Question
The fender skirts in my front wheel wells are 'sealed' to the fenders with some sort of caulk/adhesive/sealant. I never paid it much attention, however, today I noticed that on the drivers side, the 'sealant' is cracked and falling out right at the joint.
Can you tell me what should be used in this location?
Received 2,878 Likes
Hi Roy,
If that picture shows the joint between the inside of the fender and the outer lip of the apron I'd say there's likely been some bodywork in that area. There would typically be a smooth joint with just some 'bond' ooze in that location.
It's a little difficult to tell with the primer/paint? on the apron.
Does what's there feel hard like 'bond' or semi-soft like some kind of filler or sealer?
Regards,
Alan
This is the rear of the right-side front wheel well but it does show the typical fender to apron joint.
Regards,
Alan
Your photo was too close. I can not tell where it is located on the car. Back up so I can have a reference where it is. I think I know where you are talking about...but do not want to comment until I am sure.
DUB
DUB
Hi Roy,
Regards,
Alan
Regards,
Alan
The passenger side is as you describe. The material used on the drivers side is hard. That may be some of the problem too, as it is cracking and breaking apart.
DUB, If I back up, you can't see the flaw area. If you were to pull your drivers side wheel, stick your head in the opening over the disc rotor and look forward, you would get the same view on your car. The blue on the left side of the picture is the edge of the wheel opening.
Hi Roy,
Here's a picture from the left-side front on my no-hit 71.
Hope this shows you what you're looking for.
You can see the texture on the apron, inner-side of the fender and the 'bond'. It appears as though it was 'smoothed' with a brush of some sort while it was still soft. It's rock hard now.
Regards,
Alan
Regards,
Alan
Hi Roy,
Regards,
Alan
Regards,
Alan
