Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-21-2013, 11:55 PM   #1
Nightwolf_76
Junior Member
Default 81 Engine Tranny swap
I purchased an 81 with an automatic tranny. The engine is not original and I have no ideas about what kind of power it puts out. I am considering rebuilding the engine but I have no experience with rebuilds. Does anyone know what engines will drop in if I go with a crate? I would also like to put a manual in it. I'm hoping someone has experience or links that I can use to help make my decisions.
Thanks all.
Nightwolf_76 is offline   Reply With Quote
Old 08-22-2013, 01:53 PM   #2
MelWff
CF Senior Member
MelWff's Avatar
any chevrolet big block or small block will fit, you have to decide what your budget can handle
MelWff is offline   Reply With Quote
Old 08-22-2013, 02:42 PM   #3
Easy Mike
CF Senior Member
Cruise-In II Veteran
Support Corvetteforum!
Easy Mike's Avatar
Quote:
Originally Posted by Nightwolf_76 View Post
...The engine is not original and I have no ideas about what kind of power it puts out...
How does it drive? You might not need anything more than a good tune up.
Easy Mike is offline   Reply With Quote
Old 08-22-2013, 02:55 PM   #4
MIKE80
CF Senior Member
MIKE80's Avatar
I purchased an 81 with an automatic tranny. I would also like to put a manual in it. I'm hoping someone has experience or links that I can use to help make my decisions.
Thanks all.
What kind of transmission; 4, 5, or 6 speed? Any small block Chevy engine will bolt in. Mods needed if you want to go with a LS engine.
MIKE80 is offline   Reply With Quote
Old 08-22-2013, 03:47 PM   #5
tyancey00
CF Senior Member
tyancey00's Avatar
http://www.jegs.com/i/Blueprint+Engi...13CT1/10002/-1
anything carb, like this, will fit no problem. if you go with fuel injection you have some custom work to do. You will have to buy pedles and other things to put in a 4-5 or 6 speed in the car. It can be done and several are doing it as we type. Just read around.
tyancey00 is offline   Reply With Quote
Old 08-24-2013, 09:20 AM   #6
Nightwolf_76
Junior Member
Thanks for the advice. Just to clarify a big block will drop in? I'm not sure how well the engine performs as I don't have anything to compare to. There is lag once I push the gas before it goes. Not sure if something isn't adjusted right or what the problem could be.
Old 08-25-2013, 07:14 PM   #7
LannyL81
CF Senior Member
Even in perfect working order the '81 with the L81 engine and three speed auto trans is not a "get pushed into the seat" setup.
Delay could be timing is off or the carb needs rebuilding as the off idle circuit is not working. Could also be trans is slipping....need more information as to the delay.
Later
LannyL81 is offline   Reply With Quote
Old 08-26-2013, 01:29 PM   #8
commander_47
CF Senior Member
commander_47's Avatar
It is "relatively" easy to swap out a small block auto with another small block and manual trans. Especially in the 81.
There are a lot of pictures and threads in the forum on how to do it.
There are some parts to buy for the manual conversion, and you do have to dismantle part of the dash to put in the pedals and wiring and such as well as modify the console to fit the shifter.
Look at what you want to keep from the original engine. If you can use the brackets for the alternator, power steering pump, A/C etc then you can save money.
If you go with a big block, very little of what you have will work. You will have to get it all.
As is stated earlier in the thread, you need to sit down and do a little figuring as to what it is you want to do.
Do you want, or have to replace the motor? What kind of performance do you want?
Are you sure you want a manual? Do you want to run pump gas?
How far do I want to go, and how much money do I have to commit to this project?
commander_47 is offline   Reply With Quote
Reload this Page 81 Engine Tranny swap
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
