Retain stock CAI with aftermarket l-88 scoop
Decided to add an L-88 scoop to my stock 74 hood, just cause this project isnt taking long enough already.
As several others I have found online, I thought the 49" scoop didnt fit right so added 4" to bring the front of the scoop closer to the centerline of the front wheel hubs.
Used a piece of the cut hood for the straight bit, waste not want not lol
To extend the sides made forms from cardboard and plywood. Covered with wax paper.
Ok pretty basic so far. Now is where the gears started turning.
Left the stock cutout for the top of the air cleaner.Cut around it. Briefly considered making it rounder in front but stock contour looked right with the underside of the l88 scoop.
Tooke these photos then laid on another few layers to stiffen it up.
Still deciding on what to do on this end though. Im thinking glass in the hole just behind the air cleaner hole. Then do I cut the rear most support bar that formerly held the back of the grate? Im thinking I should.
Then how far to extend the bottom of the plenum chamber toward the firewall? or leave it?
Last piece is the edelbrock carb that came with my setup has a straight fitting for the fuel. Pretty much just hobjobbed to demo the motor. But its in the way of the air cleaner sitting flat. And I want something better anyway.
Anybody else running one of these carbs with a stock air cleaner? what did you do for the fuel line? Or better question what do people use for custom fuel lines these days? Just like everthing else been 30 years since I did stuff like this on a regular basis.
