69 Corvette Motor Stamped HEGG 6/98
I have a 1969 Corvette with engine stamped HEGG 6/98 - does anyone know what this means? I was told the Block was decked, I was wondering if this is a company stamp. Any help would be appreciated.
Received 1,470 Likes
Cruise-In II Veteran
Any evidence of GM numbers on the pad? What's the block casting number?
Thank you for the help. The Block numbers 3932386
1969 350 - 300 HP (early) Base 3932386 3927186 3927184 3872765 3932461
1969 350 - 350 HP (early) L46 3932386 3927186 3927184 3872765 3932461
I guess I will have to try to locate the rebuilder. I have heard that the original serial number could be found using acid etching - Just heard it once, so I know absolutely nothing about the possibilities. If anyone has any information, I would definitely appreciate it.
