Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 08-05-2013, 07:42 PM   #1
Maoriboy79
Junior Member
Default 1979 vette low mph high rpms
Hey guys im a bit new at this and am looking for a little help. i got a 79 3 speed automatic. and i just restored it after having it sit for a long period of time. the issue im having right now is that by the time im in 3rd gear im hitting about 40 mph and am in 30000rpms. i know this is way off and something must be wrong but im not sure what… if anyone can help me out that would be great.
Maoriboy79 is offline   Reply With Quote
Old 08-05-2013, 08:05 PM   #2
roadblock69
CF Senior Member
roadblock69's Avatar
Are you certain that the transmission is in 3rd gear? Do you know the rear axle ratio? What torque converter are you running? Are you certain that the transmission is not low on fluid? Not much else to check.
roadblock69 is offline   Reply With Quote
Old 08-05-2013, 08:05 PM   #3
blue427
CF Senior Member
blue427's Avatar
I think you mean 3000rpm not 30000rpms,unless you have a jet engine under the hood,then alls good,but if you have a stock 350 something is amiss. Tach may be off,check with an external tach,(i.e. an engine analyzer) your speedo may be off,check while driving along side a friend and compare speeds.Tranny slipping? Jack car up in rear and turn wheel once and count how many times drive shaft goes around,aprox3x's=308 rear 3 1/2=3.55,4+=4.10,etc.Maybe some one put a 4.56 rear in your car.There are no's on the case that will Tell you.Are you sure it's going into high gear?
blue427 is online now   Reply With Quote
Old 08-05-2013, 08:36 PM   #4
augiedoggy
CF Senior Member
Sounds to me like its not shifting past 2nd gear. TV cables or vacum out of adjustment/ off?
augiedoggy is offline   Reply With Quote
Reload this Page 1979 vette low mph high rpms
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
