4-hole carb spacer
Its funny edelbrock carbs take a lot of heat here (not literally) but I noticed this past Wednesday at a large carshow that the majority of the cars had edebrock carbs on them... Yes their were holleys and even quads on the stickers but by far the most common Carb was the carter/Weber/edelbrock series that everyone hates so much...
IMO - the mental issue........ ya, to some extent .............. I just think that it is economics. These modded double pumpers are $1000 bucks.
scott which carb do you have? 9/16ths is .563 inches
CARB VENTURI BUTTERFLY
Holley 750/750HP 1.375" 1.6875"
Holley 830 1.562" 1.6875"
Holley 850/850HP 1.562" 1.750"
Holley 950HP 1.375" 1.750"
Holley Ultra 950HP 1.600" 1.750"
Holley 1000HP 1.562" 1.750"
QFT/Proform 750 1.375" 1.6875"
QFT/Proform 850 1.400" 1.750"
QFT 950 1.450" 1.750"
Demon 750 1.401" 1.6875"
Demon 800 NEW 1.425" 1.750"
Demon 825 OLD 1.425" 1.750"
Demon 850 1.562" 1.750"
Demon 950 1.590" 1.750"
Scott
600 CFM Vacuum Secondary. Tiny 4 hole spacers are not common because you don't see 450 - 600 cfm double pumpers very often.
VS carbs are not subject to lack of booster signal do to low vacuum when all 4 throttle bores open like on a double pumper.
4 holes are to help on tall plenum single planes and would probably be detrimental in a small plenum dual plane if that is what you have.
Scott
Looks like summit Racing came through for me:
http://www.summitracing.com/parts/hly-17-59
It's mainly for insulation, in my case, but I don't think I want to use an open spacer. I would like to keep the two sides of the dual-plane intake separate. I think this spacer is what I want, even though I think it's a little pricey. Right now, with the 1" thick spacer I have on the engine, I have about 1/16" of an inch of hood clearance, this will free up an additional 1/2", which will make me more comfortable, too. Thanks for all the input, guys.
Scott
Scott
