Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
- Why Wont My Vette Start?
Guide to diagnose trouble with recommended solutions.
My Vette Won't Start
After a 6-month retro-roller cam installation, it was an anti-climactic Saturday when, after topping the fluids off and checking all connections, I turned the key, got the typical key 'buzz' and then no starter action. I've since gone back over all connections at the starter, alternator and at back of engine where the harness heads for the starter; no loose or exposed connections.
I turn key and no sound at all from starter. I checked the cables and I definitely have spark at the solenoid. My hand-held starter 'bump' trigger for setting initial timing won't even actuate the solenoid.
I am thinking I either have a bad solenoid or the battery has shorted. I did have the battery on trickle overnight after Advance Auto said I had 500cca on my PN # 75-3 battery on Saturday (pulled it off the charger midnight last night after seeing it pegged in the green and the green light flashing).
The car started fine the day I put it up on jack stands in February. 1st order of business that day was to disconnect the negative battery cable. Starter/solenoid rested on the garage floor during that whole time (dry).
I just disconnected the negative battery cable with intent of taking the solenoid and battery to Advance Auto for testing. I hope they can test the solenoid only as it is a royal PAIN to pull the starter with the right header installed.
UPDATE: I confirmed the black grounding wire is attached at the bell housing and the heavy frame grounding strap is attached to the bolt that fixes the front starter bracket and dip stick tube to the underside of passenger-side engine block. The red and purple wires that come along the harness to the starter are securely fastened to the solenoid.
Getting ready to pull the reman'd starter & solenoid and the battery to take back to Advance for testing and possible replacement. I have to say the battery has lasted the longest at 6 years. I disconn'd the analog clock several years ago and that probably added years to the battery. the starter/solenoid are 'palladium' reman'd units from Advance that I have had at least as long. So, both have lasted longer than predecessors.
is the car in park or neutral?
Received 1,246 Likes
If you have 12 volts at the top battery connection on the solenoid and you jumper-ed from there to the small terminal with the purple wire and the starter did not turn then the solenoid is bad.
Sometimes, it really helps to look at my Shop Manual ('80 L48)...
The starter solenoid has two (2) small contacts on either side of the main cable contact. I connected the small wire connector to the PASSENGER side contact. Shop manual says to connect it to the DRIVER side contact. I suspect that is the issue... small wire on wrong contact.
Advance tested the starter and solenoid four (4) times in a row and the solenoid kicked the starter into gear and spun it with GUSTO all four times.
Also, I have a frayed ground wire that attaches to the bell housing. I plan to put a new connector on that wire.
I'll be putting it all back in this evening.
Free and easy fix!
You are correct, the purple wire connects to the inboard terminal.
This diagram shows the points distributor connections.
On your HEI you don't need that (R) wire so the solenoid terminal get no wire.
There is also a large black wire that is a ground and gets connected to a bellhousing or starter bolt.
Re-installed the starter and made the correct connections. Replaced the ground wire connector @ bell housing. Engine now turns over with the key. Will be setting timing Tuesday night.
Location: Las Vegas - Just stop perpetuating myths please.
Alright Ted, good going with the wiring and i'll bet u never forget how the starter is wired now.
Can't wait to read how that roller cammed mill runs now. Are u ready for some tire smoke?
cardo0
cardo0
