PLZ Cam help!!!
Old 06-23-2013, 06:23 PM
80-81vetteguy
80-81vetteguy's Avatar
Default PLZ Cam help!!!
Looking at an 81 vette that has flat lobe on camshaft and probably bent lifter. Motor has estimated 100k I am considering top end rebuild to save money instead of rebuilding the whole thing bad idea??
would this be a good cam kit?? (should I go thumper no thumper, pros nd cons) looking for performance and sound
http://www.ebay.com/itm/COMP-CAM-CHEVY-SBC-270-MAGNUM-HYD-CAMSHAFT-KIT-305-327-350-400-/181077086520?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a29091138&vxp=mtr
will this gasket kit give me everything I need to do top end rebuild
http://www.ebay.com/itm/Small-Block-Chevy-327-350-Complete-Overhaul-Gasket-Seal-Set-Head-Intake-Exhaust-/380608191734?pt=Motors_Car_Truck_Parts_Accessories&hash=item589e041cf6&vxp=mtr
new to chevy 350s but eager to learn please help
Old 06-23-2013, 07:31 PM
7t9l82
7t9l82's Avatar
never seen a "bent" lifter, anxious to see one. what motor is in the car? is it an L-82 or something else? what transmission? what gears? really need more info. that is a good cam but depends on application.
Old 06-23-2013, 08:13 PM
80-81vetteguy
owners pretty sure it the original numbers matching L81 and its a factory 4 speed manual im assuming the gears are stock/original in the back
Old 06-23-2013, 08:17 PM
80-81vetteguy
anxious to find out what its gonna cost me to get it back on the road
Old 06-23-2013, 08:45 PM
DRIVESHAFT
DRIVESHAFT's Avatar
Very bad idea. With 100k on the engine and a bunch of ground up cam floating around inside, it's time for a complete rebuild.
Ignore the thumpr cams. They're about sound more than performance.
Even the smallest Thumpr will be a complete mismatch for an otherwise stock '81 Corvette engine.
Old 06-23-2013, 08:55 PM
scottyp99
scottyp99's Avatar
The engine is either numbers matching or it isn't. "pretty sure" sounds very suspicious. It's a way of saying "numbers matching", but still leave yourself an out if the prospective buyer checks and finds that it is not the original engine. Again, checking the numbers is incredibly easy, unless you are very visually impaired, So "pretty sure" is a cop out. Look at the front of the engine. There should be a small machined pad on the engine block, right in front of the passenger's side cylinder head. Clean that pad off, and there should be a derivative of the VIN stamped into it. That's all there is too it. It's way too easy to be "pretty sure" about it.
Same with the diff gear. It's way too easy to check to assume anything. Get the back of the car up on jackstands. Put the transmission in neutral. turn the rear tire one revolution, and count how many turns the driveshaft makes. take the car off the jackstands, and you are done.
Scott
Old 06-23-2013, 09:10 PM
80-81vetteguy
ya that's what I was kinda guessing any thoughts on ebay rebuild kits?
I would plan on upgrading it more in the future (headers, exhaust, intake) still wouldn't recommend thumper?
Old 06-23-2013, 09:13 PM
80-81vetteguy
Scott
I will definetly take a look to see plus I know I mechanic whose a chevy guy and would surley know what to look for unfortunately hes pretty busy guy and I cant ask him questions all day haha
Old 06-23-2013, 09:41 PM
80-81vetteguy
http://www.ebay.com/itm/Chevy-350-5-7-MASTER-Engine-Kit-Flat-Top-Pistons-279-Comp-Thumpr-Cam-gaskets-/190738609776?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c68e83670&vxp=mtr
What about something like this?? (does say only up to 79' though??)
Old 06-23-2013, 09:49 PM
80-81vetteguy
http://www.ebay.com/itm/Chevy-350-5-7-Car-67-85-Engine-Rebuild-Kit-/271122704638?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AChevrolet%7CYear%3A1981&hash=item3f202c28fe&vxp=mtr
Or should I get this and the comp cam shaft kit above?? im racking my brain
Old 06-23-2013, 09:51 PM
scottyp99
scottyp99's Avatar
Check this out:
http://www.northernautoparts.com/Pro...uctModelId=712
Scott
Old 06-23-2013, 09:56 PM
oldalaskaman
oldalaskaman's Avatar
for the money you spend ...fixin...you could buy a crate motor and drive sooner. fix the boat anchor at your convenience
Old 06-23-2013, 10:01 PM
DRIVESHAFT
DRIVESHAFT's Avatar
I still wouldn't recommend a Thumpr.
I would recommend that you pick a cam for performance, not for sound.
Any cam that is as large as the Thumpr cams are will give you a nice lopey idle, without the loss of performance caused by the excessively long exhaust duration of the Thumpr cams.
Old 06-23-2013, 10:04 PM
80-81vetteguy
ah that's cool they let u upgrade kit as u like
but im definitely not sure what combo of parts would be best? I would like to get the car around 300-350 hp once im all done with it (after headers, exhaust, intake, etc. at later date) any recommendations?
Old 06-23-2013, 10:12 PM
80-81vetteguy
avoid thumper cool thanks for the input
Old 06-23-2013, 10:22 PM
80-81vetteguy
Originally Posted by oldalaskaman
for the money you spenbd ...fixin...you could buy a crate motor and drive sooner. fix the boat anchor at your convenience
http://seattle.craigslist.org/tac/ptd/3885882489.html
question too is should I worry about the cam being its built for a truck?
Old 06-23-2013, 10:26 PM
oldalaskaman
you can buy new from jegs with free shipping for the same price
To PLZ Cam help!!!
Old 06-23-2013, 10:30 PM
80-81vetteguy
ya ive looked at jegs selection and the cheapest they have is 1,500. More than this motor http://seattle.craigslist.org/tac/ptd/3885882489.html
and the jegs isn't complete
Old 06-23-2013, 10:35 PM
80-81vetteguy
here is the link for the vette I am looking to purchase
http://seattle.craigslist.org/sno/cto/3876921795.html
Old 06-25-2013, 12:00 AM
80-81vetteguy
Quick Reply: PLZ Cam help!!!
