Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Albums Search Today's Posts Mark Forums Read FAQ
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-22-2013, 03:54 PM   #1
langlj00
CF Senior Member
Default 'New' Carb. soot on driveway whilst on choke - Help
Hi,
I've just replaced the QJet on my 1974 350 Auto. - It wouldn't idle when hot - turns out the air horn was warped.
So I've got a replacement from a 1975 Auto. This carb. is a big improvement, starts from cold first time, idles smoothly when hot (or cold) and the idle mixtures screws are responsive (which the old one were not).
The ONLY problem with it is that is leaves soot markson the drive from the exhaust tips when I back it out of the garage from cold. I guess it is too rich when on choke.
I have an electric choke fitted (which works fine in terms of getting the car running when cold) - I've tried truning it clockwise to 'lean' out the choke, but that doesn't seem to stop the black marks on the drive (that I'm sure the wife will not be impressed with when she works out what is doing it ).
Thanks,
Jeremy.
Constructive comments please - (change the carb. is only partially useful!).
langlj00 is offline   Reply With Quote
Old 06-22-2013, 07:34 PM   #2
REELAV8R
CF Senior Member
REELAV8R's Avatar
If this is not a winter or daily driver I would remove the choke all together. Just take out the choke "plate" in the throat of the carb by removing the two screws holding it on would be the easiest way. Careful you don't drop the screws into the carb. To be safe stuff a rag in the throat while removing the screws so if you do drop one it is in the rag and not down the intake manifold.
REELAV8R is offline   Reply With Quote
Old 06-22-2013, 07:46 PM   #3
jotto
CF Senior Member
jotto's Avatar
J,
Without trying to teach his grandmother how to suck eggs, I assume you have adjusted idle mixture screws for best vacuum etc? How far out from seated are they?
jotto is offline   Reply With Quote
Reload this Page 'New' Carb. soot on driveway whilst on choke - Help
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
