TPI intake ducting
Old 06-20-2013, 06:05 AM
waljr
waljr's Avatar
Default TPI intake ducting
I've had a TPIS miniram setup on my '80 for a while now with a slinky hose duckting to the air filter mounted in front of the air con.
Has anyone got or know of a better setup.
I'm thinking about cutting a hole beside the radiator to get the air filter in front of the radiator.
or runnuing through the origanal ducting over the radiator & into an airbox / filter.
fyi, the clutch fan is gone, I'm running a couple thermo's
Old 06-20-2013, 08:20 AM
oldalaskaman
oldalaskaman's Avatar
we need to see pictures, thats a swap I'm thinking about
Old 06-20-2013, 08:43 AM
mrvette
mrvette's Avatar
Get to one of my sites below, maybe have to copy/paste, and there are pix of how I did my up/over air induction....
Old 06-20-2013, 10:26 AM
DC3
DC3's Avatar
You flipped your hood to open bassackwards. Any way to run your type of setup with a normal hood?
DC
Old 06-20-2013, 03:20 PM
mrvette
mrvette's Avatar
DC
NOPE, and the hood opens like every other car NOW!!!! what you mean ackbasswards???
Old 06-29-2013, 09:01 PM
waljr
waljr's Avatar
just adding a link to simlar post
http://forums.corvetteforum.com/c3-t...ction-box.html
Old 06-30-2013, 01:52 AM
Bangkok Dean
Bangkok Dean's Avatar
I run a air filter in front of the rad by notching the top of the rad shroud and shorting the hood prop to restrict the opening. The filter sits about 4 inches above the oil cooler so it don't get too much water splash.
The air feed is 4 inch diameter tubing that is flattened oval where it goes over the rad. I don't have FI but this should work the same as my carb system cold air feed.
To TPI intake ducting
Quick Reply: TPI intake ducting
