1978 steering wheel snap ring help
Old 06-18-2013, 07:51 PM
DSvett
6th Gear
DSvett's Avatar
Default 1978 steering wheel snap ring help
I am having trouble replacing the snap ring on the locking plate after I replaced my turn signal switch. Suggestions?
Old 06-18-2013, 09:49 PM
CF6873
CF6873's Avatar
Do you have a plate depressor tool? that is the easiest way that I know to reinstall the snap ring. Just depress the plate and slide the ring over the shaft until it snaps in place.
Old 06-18-2013, 09:51 PM
DSvett
6th Gear
DSvett's Avatar
No. I thought there might be a tool. I did not know what or where to get one. It's not easy trying to push the locking plate in by hand.
Old 06-18-2013, 09:57 PM
TimAT
TimAT's Avatar
You can borrow the tool from Auto Zone or O'Rilley's. Makes it lots easier.
Old 06-18-2013, 09:59 PM
DSvett
6th Gear
DSvett's Avatar
Thank you. I was just looking that up. Hopefully it's goes on as easy as it came off. Thanks again.
Old 06-19-2013, 06:31 AM
Jim Shea
Support Corvetteforum!
Jim Shea's Avatar
In order to use the special tool (I call it a lock plate compressor) you also need to lock the upper steering shaft from telescoping. Usually tightening the star screw locks the upper and yoke shafts from telescoping.
However, the special tool usually interferes with the star screw. So you want a small set screw with a 5/16-18 UNC thread or a #20 Allen screw to replace the star screw. Tighten the set screw and the two shafts won't telescope. Then the special tool will work correctly.
Jim
Old 06-19-2013, 08:30 AM
Capt Ken
Capt Ken's Avatar
Default Diy
The compressor tool is the right way to do it. My local Auto Zone doesn't carry it. On my column there is an empty ~1/2" hole at the 2 o'clock position. I was able to use a screwdriver through this hole to compress the spring enough to get the clip on.
Old 06-19-2013, 10:48 PM
DSvett
6th Gear
DSvett's Avatar
Thanks that worked great. The information about locking the shaft with Allen screw was key. Everything is back together and back on the road!
To 1978 steering wheel snap ring help
Quick Reply: 1978 steering wheel snap ring help
