Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Search Today's Posts Mark Forums Read FAQ PhotosGarage
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 06-25-2002, 02:14 AM   #1
74-Roadster
CF Senior Member
St. Jude Donor '06
Father & Son St. Jude Donor '09
74-Roadster's Avatar
Default Re: CONFUSED AS HECK with door hinge spring installation instructions! (Rick Church)
If one of your doors has one, look at the position of the spring. I used the tool you're supposed to get and a small mirror and a flash light. Put the spring in like the directions say and use the tool and mirror from below and it will snap into place. I was confused but figured out while trying to get it installed. It all seems so simple now.
74-Roadster is offline   Reply With Quote
Old 06-25-2002, 05:06 AM   #2
tunedport78
CF Senior Member
tunedport78's Avatar
Default Re: CONFUSED AS HECK with door hinge spring installation instructions! (74-Roadster)
try these instructions, there alot clearer http://www.corvetteforum.com/guides/c3/c3doorspring.htm
I did mine. It was confusing at first but once I figured it out it was real easy. Theres just no easy way to explain it.
Vic
tunedport78 is offline   Reply With Quote
Old 06-25-2002, 09:59 AM   #3
Paul 75 L82
CF Senior Member
Paul 75 L82's Avatar
Send a message via AIM to Paul 75 L82
Default Re: CONFUSED AS HECK with door hinge spring installation instructions! (tunedport78)
You have to have that special tool to do the job. I felt the same way, but after i got going it only took about 30 min.
Paul 75 L82 is offline   Reply With Quote
Old 06-25-2002, 10:26 AM   #4
BlueL36
CF Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
BlueL36's Avatar
Couple of things-
Put a towel or other cloth object between the door and the body below the hinge to "catch" the spring when it falls. It may fall a couple of times as you're fiddling with it and this will protect the paint.
Second, you can make a tool by sacrificing an old screwdriver. It has to be stout enough to hold the bend you'll need to put into it to use as a lever. Also, by using a longer, big-handled screwdriver as a mallet (handle end as hammer) you can tap the bottom of the spring up into place as you use the bent screwdriver to hold the spring over toward the body. Smaller than a hammer and the wood/plastic handle is a bit safer around the paint.
Took all of two minutes to install the spring once I figured this out.
BlueL36 is offline   Reply With Quote
Old 06-25-2002, 03:51 PM   #5
71roadster
CF Senior Member
71roadster's Avatar
Default Re: CONFUSED AS HECK with door hinge spring installation instructions! (BlueL36)
I made a tool by sacrificing a small open end wrench. I notched the handle of the wrench just enough so I could get it in position around the spring, torqued the sprind and tapped it up into place with a hammer. I like the wrench better than the screwdriver method because is is much less likely to slip and gouge out paint or an eye ;)
Chris
71roadster is offline   Reply With Quote
Old 06-26-2002, 01:02 PM   #6
fontking1a
CF Senior Member
fontking1a's Avatar
I did my drivers door about seven or eight years ago. I ordered two springs (one spare) and the tool. After scratching my head for a few minutes and thinking about it....and reading how to do it......I did it. It seemed way worse than it actually was but when I was doing it...it only took a couple of minutes. That's all I can remember. You do need a tool...that's for sure. Wish I could remember more but it just seems to me that if you start the job...you'll figure it out as you go.
fontking1a is offline   Reply With Quote
Reload this Page CONFUSED AS HECK with door hinge spring installation instructions!
Tags
75, corvette, door, hinge, install, installation, instructions, spring, tool
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.2
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.1 PL1
Emails & Password Backup
