tripower ss fuel line leak
I just installed a Stainless Steel fuel line set on my car and I cant even run it long enough to see how many are leaking due to how bad it is. Im not sure what to do. I spent the money on these and would like to use them, but am at a loss of where to go from here. I have them as tight as i feel comfortable doing with the fittings. I really wana start the car for the first time and this is definitely holding me back. Thanks for the help
I tried a SS fuel line, pump to carb. I couldn't stop the leaking. Best I could do was reduce the leak to seeping. This was after repeated loosening and tightening. I think the problem was the fuel line didn't line up square with the fitting on the carburetor. SS lines are quite stiff comapred to sotck lines, they probably won't conform as easily if the line isn't perfectly straight coming into the fitting.
I'm not familiar with the details of a tri-power. Would it be possible to buy fresh fittings for the carbs, seats wouldn't have any impressions left by a prior installation? Verify the alignment of the lines are correct, try again?
Thanks for the replys, they are new brass blocks and new in the fittings in the carbs aswell. I've had them on and off twice, maybe I need to loosen and re tighten them a few more times? They didn't seem to change at all tho between the two tightenings. I wish they were just seeping, I might as well not even have the lines connected. I saw these flare saver things on here in some other post but don't know if anyone has used them. They were made from aluminum and looked like they would work I think. The only thing was one of them said they were for 37 degree flares. Not sure what these are on yhe car but they might be 45 not 37. Maybe there's other ones out there also? Or maybe the 37 would still work and the aluminum would just conform to the fitting?
I purchased steel ones from Classic Tube (made in U.S.A.) and they fit perfect,tighten a little at a time,making sure they're seated and they shouldn't leak.
well then i guess the ones i bought from ''the right stuff'' are junk and i'll just throw them out,what brand should i buy ,since you must sell better ones?
only the cheap ones arnt plyable,ss is double annealed and bends just like steel lines,,you could also try ''Copper Flare Gaskets'' for hvac lines
I can't seem to make these seal and the company is willing to send me a new set of ss or steel, so I just went with steel and hope they work better. Thanks for all the help. I guess I have set of ss lines that just need some flare savers if I ever decide to change
You should have much better luck getting steel ones installed. You still may have to fiddle with them a little, to keep them from leaking, but you'll have a much better chance of stopping the steel ones from leaking.
Take the lines off the car. Make sure there is no gas in them and heat the flared ends with a torch. This will get some of the temper out of the stainless steel and make them a little more flexible. I've done it with stainless brake lines too.
