Birdcage repainting around windshield
I've got my windshield out (old one cracked) and I want to refinish and repaint the birdcage. There's no rust. But it was painted body color during the last restoration. I want to paint it black.
What's the best way to remove the rest of the windshield urethane and repaint? Do I need a special paint or primer around the windshield? I'm concerned about getting the surface right so the new windshield adheres good and solid. Don't want it pulling the paint off and flying out.
Received 1,468 Likes
Cruise-In II Veteran
All birdcages were primed and painted before the glass was installed. I'm not sure you have to worry about adhesion. Talk to the windshield installer and see what they say.
wire wheel on your drill is the best way to get that stuff off (wear a face mask unless you want to rock a speckled, black face)
it is better to use automotive (not rattle can) paint because (in general) it adheres better, and it seals the metal better. That said, I've only had one windshield pop out - and it did so because the metal underneath the windshield had rusted completely away
i just did mine last year when I pulled the old cracked windshield out before new paint went onto the new car. I wire wheeled the entire windshield frame to bare metal then I used an self etching primer from NAPA. It is very similar to what the factory used. Then after two coats of that I used POR 15 on the entire metal surface. There was no adhesion problems and when the glass installers came they were very impressed at how everything was all set and ready to go for the new windshield.
best of luck,
Sully
best of luck,
Sully
best of luck,
Sully
best of luck,
Sully
Received 2,878 Likes
So if you were to look at the pillar from the window side, between the molding and interior trim, would you see black or zinc chromate? How far around the edge did the blackout go?
