Rear Bearing Set Up
Old 05-30-2013, 09:10 PM
HBZ_81_C3
HBZ_81_C3's Avatar
Default Rear Bearing Set Up
Toms spindles with new Timken bearings and races.
Thoughts on bearing set up at .0000 to -.0005?
Old 05-30-2013, 09:13 PM
Mike Ward
Mike Ward's Avatar
Kaboom.
Old 05-30-2013, 09:26 PM
HBZ_81_C3
HBZ_81_C3's Avatar
Originally Posted by Mike Ward
Kaboom.
Thanks for the reply... but on what basis did you derive this?
Engineering data from Timken states that the bearings may be preloaded up to -.0015. I'm looking to have the best set up possible without having any movement what so ever in the bearings when at operating temperature.
This way the entire bearing compliment is sharing the load rather than part of the compliment on each bearing.
Old 05-30-2013, 09:40 PM
Mike Ward
Mike Ward's Avatar
Based on generations of guys who tried the same thing as you propose.
If you were to set the bearing up at -.0005" at room temp, what would the clearance be at max. operating temp when it really counts.?
Old 05-30-2013, 09:59 PM
HBZ_81_C3
HBZ_81_C3's Avatar
That is just what I was hoping to find with this thread. Someone with real world experience on this.
Everything in there grows when it heats up. We know that. The bearing and race expansion is not a factor at the operating temperature of the assembly. The cast steel bearing housing will grow very slightly, but negligible. The spindle will also grow, but I'm betting it will grow more in length ...
Therefore my thoughts, at this point are there would be +.000? atrunning temperature.
Old 05-30-2013, 11:25 PM
427Hotrod
427Hotrod's Avatar
Received 1,875 Likes on 913 Posts
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I set mine at .0005" many years ago when I installed them. I pulled them down a couple of years ago to inspect and re-lube. Still looked brand new and went back together with same dimensions. Many miles and many many dragstrip passes.
I've always set them up at .001" or less even on stockers.
JIM
Old 05-31-2013, 07:14 AM
HBZ_81_C3
HBZ_81_C3's Avatar
JIM
Thanks Jim!
Old 05-31-2013, 07:25 AM
Indiancreek
Support Corvetteforum!
Indiancreek's Avatar
I'd suspect if you contact the company, they'll have the answer for you. It sometimes results in information from an engineer that isn't the same as what many term as rule of thumb.
I had that situation with cylinder wall minimum thickness, when I contacted the manufacturer I was surprized with the response from them.
I'd bet that their engineer will be able to tell you the expansion rate of all those materials, and how they relate to one another.
Old 05-31-2013, 11:46 AM
gcusmano74
gcusmano74's Avatar
If you set them up at 0.001" to 0.002", I'm sure you will be fine. I would not preload them, myself.
Old 05-31-2013, 08:01 PM
HBZ_81_C3
HBZ_81_C3's Avatar
It's done... set the bearings up at .0000.
Required a bit of work on the surface grinder to get the shims to the thickness needed.
To Rear Bearing Set Up
Quick Reply: Rear Bearing Set Up
