I'm leaking blinker fluid!
05-15-2013, 03:04 PM
Made you look!
05-15-2013, 03:18 PM
was wondering if you are running a blinker fluid filter?
05-15-2013, 04:11 PM
Quote:
Originally Posted by
billcarson
Nah, I think the modulator O rings are leaking
05-15-2013, 05:12 PM
Have you checked your flux capacitor lately?
Scott
05-15-2013, 07:04 PM
You need to pull your horn button and jam a screwdriver as far as you can push really hard. And if the fluid is touching the end of the screwdriver you're having worst problems then I can help you with.
05-15-2013, 07:10 PM
I think my air filter is leaking too.
05-15-2013, 07:29 PM
genuine1980
You mean it won't hold air anymore? Geez, that's not good at all! Speaking of air, that reminds me, it's getting to be time to let all the winter air out your tires, and replace it with summer air.
Scott
05-15-2013, 07:39 PM
I'm thinking about installing a speedometer cable ratio reducer, to get my speedometer to tell the correct MPH. Hah! Jokes on you, speedometer cable ratio reducers actually exist!
Hey, if you like techno-gibberish, you'll die laughing when you watch this:
Scott
05-15-2013, 08:11 PM
"no wait"!"the moderators will put a stop to this".
05-15-2013, 09:27 PM
follow your draft line I bet its full of A1R.
05-15-2013, 11:30 PM
Terrorizing Orange Cones
Thanks for the laughs, Scottyp99... you guys crack me up. BillCarson always has the best photos to go with any post.
What's next? Muffler bearings vibrating badly?
05-15-2013, 11:41 PM
It's more likely halogen leaking from the headlight when they're closed...
05-16-2013, 02:00 AM
I'm so confused! I lost my 710 somewhere and need a new one.
05-16-2013, 11:28 AM
Bagmup
What does it do when they're open?
05-16-2013, 11:31 AM
Why do my tires only go flat on the bottom ?????
05-16-2013, 11:32 AM
oldsarge
It's an atmospheric pressure thing, you need to drive faster to get more air under the car
05-16-2013, 12:46 PM
If there were ever a car that could leak blinker fluid, the Corvette would be that car.
05-16-2013, 12:50 PM
Crash80
05-17-2013, 12:26 AM
Navigator
how is the beep charge holding out?
05-17-2013, 02:28 AM
AirborneSilva
ok but what happens at 120mph?
