Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 05-08-2013, 06:36 PM   #1
bravados
Junior Member
Default Top Radiator Hose
Well after a run this weekend i noticed steam from my engine bay. Popped the bonnet and the top radiator hose had come off the radiator connection. Waited for it to cool, replaced coolant and put together and tightened the clip.
Went for another run and popped bonnet to check and noticed air bubbles comming from the connection and a slight drip/leak.
Question is, do we feel this is still just a loose connection and needs tightening further? Should there be some sealent in the connection?
bravados is offline   Reply With Quote
Old 05-08-2013, 07:22 PM   #2
jnb5101
CF Senior Member
jnb5101's Avatar
the hose is probably damaged internally. make sure that bubba hasn't damaged the radiator nipple in some past attempt to remove an old hose. some guys like to use razor knives to slit a hose. no sealants are used on the hoses.
jnb5101 is offline   Reply With Quote
Old 05-08-2013, 08:08 PM   #3
mds3013
CF Senior Member
mds3013's Avatar
When this has been covered in the past the problem has been an incorrect size I.D. on the hose. No amount of tightening or replacing the clamps would stop it. The hose should fit very snug onto the radiator neck. mike...
http://forums.corvetteforum.com/c3-t...ing-off-4.html
mds3013 is offline   Reply With Quote
Old 05-08-2013, 08:10 PM   #4
calwldlife
CF Senior Member
calwldlife's Avatar
I have smeared red RTV on the pitted neck to
seal the hose.
no issues.
calwldlife is offline   Reply With Quote
Old 05-08-2013, 09:06 PM   #5
gcusmano74
CF Senior Member
That will work. The trick is not to use too much. The extra sealant can get loose and clog a few radiator tubes.
gcusmano74 is offline   Reply With Quote
Old 05-09-2013, 02:56 AM   #6
bravados
Junior Member
Guess a new top hose would be an idea then see how it goes.
Out of interest where is this radiator nipple and what does it do?
Thanks all
Old 05-09-2013, 04:08 AM   #7
Bagmup
CF Senior Member
Bagmup's Avatar
I think he means the top outlet on the radiator.
Bagmup is offline   Reply With Quote
Old 05-09-2013, 09:23 AM   #8
Easy Mike
CF Senior Member
Cruise-In II Veteran
Support Corvetteforum!
Easy Mike's Avatar
Since you used the term "bonnet" you will have to define what you are calling a radiator nipple.
Easy Mike is offline   Reply With Quote
Old 05-09-2013, 03:29 PM   #9
oldC3guy
CF Senior Member
oldC3guy's Avatar
I think MDS3013 has the right diagnosis. Recently I bought a new upper hose for my '78 L82. Inner diameter on the engine end was too big so back to the store to exchange it for the right one. It should fit snug when putting on.
oldC3guy is offline   Reply With Quote
Reload this Page Top Radiator Hose
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
1982 transmission cooling lines Bikergems C3 Tech/Performance 7 05-11-2014 08:59 PM
Radiator Supply Tank without heater Larry N. Johnson C1 & C2 Corvettes 11 05-01-2013 11:01 AM
Cracked Radiator Neck ? BACNBLK C5 General 7 04-11-2013 09:06 PM
Bad to Worse MotorCity_87_C4 C4 General Discussion 8 10-06-2012 03:50 PM
TB hose to radiator replacment BucfanTitan C4 Tech/Performance 10 07-27-2012 07:30 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
