Front blackouts don't fit!
Old 05-07-2013, 10:58 PM
augiedoggy
augiedoggy's Avatar
Originally Posted by qwank
or C4s
Wow , OK I see the real problem here
Old 05-07-2013, 11:07 PM
BOOT77
BOOT77's Avatar
Originally Posted by augiedoggy
then you've got some major issues if your engine doesn't reach the temp to activate it.... these cars run hot when running correctly not too cool.
I shoulda went into more detail I guess but I couldn't think how to put it w/o getting advise on ten other things.
So let me put it this way. When you go really really fast at cooler spring/fall nights only and it shuts your t-stat and then it spikes kinda high B4 it opens because the engine is hot, but the high speed cooled the rad too much. I race at night and this is something that will block the rad some and I can take off in the day. Blockin gthe grills will give me a small aero + instead of blocking the rad.
Old 05-07-2013, 11:17 PM
7t9l82
7t9l82's Avatar
i worry a lot more about the car running hot than i do running cool.
Old 05-07-2013, 11:38 PM
augiedoggy
augiedoggy's Avatar
Ok I see now why your looking at them...I did go through two sets as well as made some replacement pieces myself for the ones on my old 84.. they looked cool but did not fit very well and fell off at times....the second set I bough had rubber like trim around them to protect the already trashed paint from the first set I also used a grinder to reshape them a bit to fit in the recessed openings and fill them correctly.
Old 05-08-2013, 10:22 AM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
C3s bring cooling air from the bottom, under the chin. Very little cooling air comes from the grilles. Regardless of the fit, your blackout kit would have very little affect on the cooling system.
Old 05-08-2013, 02:49 PM
Alan 71
Alan 71's Avatar
Received 2,878 Likes on 2,515 Posts
Hi,
I agree that our cars breath from the bottom, so removing the spoiler might have the desired effect.
I don't think that's an x, y, z, suggestion, maybe just a d suggestion?
Regards,
Alan
Old 05-08-2013, 04:15 PM
BOOT77
BOOT77's Avatar
Originally Posted by Alan 71
Hi,
Regards,
Alan
That would be a B,C solution. Your in the same area and the same concept(less air flow). Plus I have read about the extened air dam being use in a more cooling needed situation. I considered extend for more areo, but knew it would make my problem worse. Also I know some have a problem overheating when they are removed. I'm a lil gunshy on trying that move. I read about Beejay making some grill covers and running 10-20 degrees hotter I think, so figured I wuold give it a try.
Old 05-08-2013, 09:32 PM
BOOT77
BOOT77's Avatar
My blackouts are the kind with the outer weatherstripping so I peeled it back and trimmed them on the plate side and uppper corner and they fit pretty snug, part of them pops behind the top lip. I'm tempted to leave them in and see what happens, it's kind of a pain to get them out once popped in. Still I think I need to scure them some so they don't flap on the blinker loose end, it's inside and won't pop out just has some wiggle room. I might use the sticker body 90 degree mounts attacjed to the backside of the blackout and drill a couple holes in the velcro sides to use zip ties thru the grill to help hold em on.
Old 05-08-2013, 09:35 PM
BOOT77
BOOT77's Avatar
Just thought of it, might use some stick on weather striping on the backside by the blinker to take out the wiggle room and make them snug there.
Old 09-09-2013, 05:45 PM
villare
villare's Avatar
Default Post Pictures Please
Hey Boot77, would you please post pictures of the blackout kit intalled on your vette...i have had the kit for years and have not put it yet i wanted to see how they look on your vette, thanks.
Old 09-09-2013, 07:30 PM
F4Gary
F4Gary's Avatar
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Sounds like some cardboard and tie wraps would do the trick. Just cut the tie wraps and take them off when you aren't racing at night.
Old 09-09-2013, 08:33 PM
donnie1956
donnie1956's Avatar
Lets see some photos of the blackouts?
Old 09-10-2013, 07:57 AM
  #33
BOOT77
BOOT77's Avatar
I'll pop them in and snap a pic when I get a chance, it'll be kinda a close up because the car is on jack stands in the garage with the front towards the back. I got sidetracked by so much this summer I never ran them after fitting and kinda was saving them for my new wheels that took way longer than planned. So I don't know how well they would of held up. But if I get the car out soon I'll deff have them on.
FYI for the heat part of the disscusion. I was already running under drive pulleys and about mid-july I swapped to a smaller crank pulley to slow the water pump/fan down some more and my temp is still 160. From a 5.75" too a 4.75" crank pulley and I lowered the alt pulley to keep the same amps.
Old 09-10-2013, 09:43 AM
  #34
1977L48
1977L48's Avatar
if you put an under drive kit on the crank and its still not getting above 160* I would really check the gauge for accuracy, what radiator are you running?
Old 09-10-2013, 11:18 AM
  #35
bashcraft
bashcraft's Avatar
What temp thermostat are you using? If it's anything other than a 160, it's not working.
Old 09-10-2013, 07:38 PM
  #36
BOOT77
BOOT77's Avatar
An open thermostat is less pumping ressistance. I wouldn't run one, but then it would take forever to warm up. If I wanted to put the temp at what ever I wanted. I would put a higher temp thermostat in but it would be closed a lot, because my engine does not produce much heat and is maybe overcooled. Thermostats help the engine warm up if you run too hot a lower stat will only delay that maybe. If an engine wants to run 200 and has a 160 stat it'll run 200. My goal is to get the car to run hot enough to have an open stat after it warms up. I can either make more heat or cool less and I'm trying to do that w/o causing further ressitance. Maybe it's not a huge loss, but it's my goal. Blocking the radiator would be ok but I'd rather try a smaller fan. Blocking the front grills should have some small aero benefit and is not the same as the radiator, but less effective.
Old 09-10-2013, 08:05 PM
  #37
1977L48
1977L48's Avatar
Do the Iowa trick, put cardboard infront of ur radiator
To Front blackouts don't fit!
Old 09-11-2013, 06:40 AM
  #38
The Punisher
The Punisher's Avatar
A picture would be cool
Old 09-11-2013, 06:48 AM
  #39
bashcraft
bashcraft's Avatar
Are you serious? This is probably the dumbest thing I've read on this forum in quite awhile.
Old 09-11-2013, 12:25 PM
  #40
76Rat
76Rat's Avatar
Install an electric water pump and an adjustable sensor to kick the water pump on when needed or at the temp you want. This way you have less resistance from the water pump.
Turn the pump off when racing. No resistance.
Quick Reply: Front blackouts don't fit!
