Electric clutch on ac unit
Old 05-14-2013, 08:15 PM
mattu
mattu's Avatar
Default Electric clutch on ac unit
could anyone tell me how to replace the bearing on an electric clutch on an air conditioning compressor on a 77? the clutch is off compressor
Old 05-14-2013, 08:37 PM
mds3013
mds3013's Avatar
The bearing is pressed out of and then back into the hub. I had an old school auto parts store do mine. They found a new old stock GM bearing. This pic. shows the disassembled clutch but you do not have to take it down this far. Find the bearing and have someone with a press and some know how press it for you. Hope this helps. If I can find the part number I will post it. mike...
Old 05-14-2013, 08:48 PM
mattu
mattu's Avatar
thanks for the pic and the help! do you know how the bolts come out of the retainer clips? do you have to bend each one of those clips?
Old 05-14-2013, 09:00 PM
mds3013
mds3013's Avatar
The bolt retainers are a little difficult to deal with. I could not find any new ones. I just lifted the long edge that is bent down over the front of the clutch so I could turn the bolts but left the tabs tight against the bolt head. I used a small crescent wrench to turn the retainers with the bolt. I marked the orientation of the clutch outer pulley hub and inner bearing hub. Then maintained the position of each bolt to reassemble it just as it had been. You can see how the bolts and the retainers are together in the pic.. If you do not need to remove these bolts than I would recommend not to do so. mike...
Old 05-14-2013, 09:13 PM
mattu
mattu's Avatar
i would imagine i'd have to take those bolts out to get the bearing pressed out. thanks for your help!
Old 05-14-2013, 09:17 PM
mds3013
mds3013's Avatar
I do not think so. The pulley is not in the way. The back surface of the bearing hub should support the pressing operation. I may be remembering incorrectly however. I have slept since then. mike...
Old 05-14-2013, 09:29 PM
mattu
mattu's Avatar
ok will check it out tomorrow...thanks again!
Old 05-15-2013, 04:38 PM
mattu
mattu's Avatar
mike, got it apart, did have to take the bolts out, but did it the way you said, thank you. do you remember where you got the bearing or what the part number was???
To Electric clutch on ac unit
Quick Reply: Electric clutch on ac unit
