Dead 69... fusible link?
Old 05-05-2013, 03:21 PM
jbroughton
jbroughton's Avatar
Default Dead 69... fusible link?
Pulled the 69 out of the garage yesterday, shut it off for just a minute to load some things in the car. When I tried to crank it back up, EVERYTHING is dead. No clicking from the starter, no lights, no clock, no radio. Battery shows 12.5 volts, with clean connections there. Will a bad fusible link cause this? Any other ideas? Just wondered where to look first. Thanks!
Old 05-05-2013, 04:37 PM
scottw
scottw's Avatar
Yes it can. Take your voltmeter and start tracking it down. You know the battery is good. Look at the fusible link and then start at the hot wires on the starter and keep working your way until you find no power.
Old 05-05-2013, 05:08 PM
gve
gve's Avatar
Check the ground wire where it bolts to the frame, also make sure the starter bolt is tight
Old 05-05-2013, 05:11 PM
Dave J
Dave J's Avatar
Same thing happened to me years ago on my '70. Ended up being the fuse link at the horn relay.
Old 05-10-2013, 10:23 AM
jbroughton
jbroughton's Avatar
Thanks guys, it was indeed the fusible link!
Old 05-10-2013, 11:26 AM
Dave J
Dave J's Avatar
Which One?
To Dead 69... fusible link?
Quick Reply: Dead 69... fusible link?
