Something is up with my temp gauge.
So a while after changing from my stock air cleaner to a new one, my temp gauge stopped working. I put in a new sensor today, still nothing. It does peak when I ground it using a test light though, as I have seen online.
I understand this could mean that it's not calibrated, is there a way to re-calibrate it? Any other troubleshooting I could do? I noticed one of my fuses is out, could that be the problem?
Sure that sender was for a gauge and not a light?
I'm not quite sure, it was the sender that the store I bought from recommended. I will admit it doesn't look exactly like the old sender I took out, I'll see if I can find a pic for it online.
By the connector, you are referring to the wire right?
Temp gauge help
Hi,
Read this form Willcox. There is a lot of info on their site for anything you might run into working on your vette.
Ron
http://willcoxcorvette.com/instructi...Revised_R3.pdf
Ron
Hi,
Ron
Ron
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Testing a 68-76 Temperature Gauge -or- What your non working gauge can tell you!
