Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Search Today's Posts Mark Forums Read FAQ Vendor Directory
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C7 Parts & Accessories
C6 Parts & Accessories
C5 Parts & Accessories
C4 Parts & Accessories
C3 Parts & Accessories
C2 Parts & Accessories
C1 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 04-19-2013, 04:54 AM   #1
plansch
Junior Member
Default Tech Specs for 90' LS6 crate engine
Hi,
does anyone have the original documentation and specifications for the LS6 engine sold in the 90' GM perfomance parts catalogue under part # 366250 (engine code XAA)?
Or can someone tell me where I can ask for it?
Thx
Marcel
plansch is offline   Reply With Quote
Old 04-19-2013, 09:47 AM   #2
1977L48
CF Senior Member
1977L48's Avatar
have you tried contacting a dealership near you? i know mine was helpful with looking up very old cam stuff, from the 60's and 70's.
1977L48 is offline   Reply With Quote
Old 04-19-2013, 10:08 AM   #3
plansch
Junior Member
no, didn't try that because my next dealer is some thousand km away...
I'm not from the US... Do you have a contact for me who might help a foreigner?
Old 04-19-2013, 10:12 AM   #4
1977L48
CF Senior Member
1977L48's Avatar
if you like i can call for you. is that the only information you have off the engine?
Old 04-19-2013, 10:25 AM   #5
1977L48
CF Senior Member
1977L48's Avatar
ok, from what the parts guy at the dealership told me was, its a replacement LS6, 454-450 hp 500 ftlbs , 11.25 comp ratio, solid flat tappet cam, the entire kit and kabootel.
Old 04-19-2013, 10:34 AM   #6
plansch
Junior Member
Thats a realy fast service...
But I think the comp ratio is not correct. In the '90 catalogue is said it has 10,2:1. I have a copy of the catalogue page and an original catalogue is on the way.
What I am looking for is more detailed tech information... as far as I know with actual crate engines there is a installation and tech specs document delivered with it. I don't knw if something like this exists for my 'old' engine. I'd like to have infos like recommended ignition timings etc...
Old 04-19-2013, 10:36 AM   #7
plansch
Junior Member
here you can find the catalogue infos:
http://www.hemmings.com/parts/item/3844.html
Old 04-19-2013, 10:37 AM   #8
1977L48
CF Senior Member
1977L48's Avatar
for that info i cannot help you, i would say run what the 70 specs was, im just going off what the guy told me over the phone from chevrolet. sry i could be more help
Old 04-19-2013, 10:48 AM   #9
1977L48
CF Senior Member
1977L48's Avatar
XAA is a code for a 10.2 / 1 compression crate engine. GM substituted 118 CC Open Chamber Rect Port Heads on the XAA crate motors to get compression down to 10.2. Internally the XAA motors are exactly the same as the earlier higher compression LS6 motors. The only exception I can find in my engine is the change to the open chamber heads. Pistons, rods, crank and cam are identical between the XAA crate motors and the earlier LS6 configuration. I bought my engine new so I am sure it is as built by GM without any chance of anyone messing around with head substitutions
Old 04-20-2013, 12:39 PM   #10
roadblock69
CF Senior Member
roadblock69's Avatar
From memory, the short block is the '70 version with the stated 11.25:1 compression. However; The heads were the later open chambered design lowering the compression ration to 10.25:1. I also believe that the crate motor was not equipped with the 7/16" push rods. It came with the 3/8" found on earlier solid lifter engines. The heads are cast iron, had the big valves and rectangular ports. About the same as a '71 Ls-6 Corvette engine but with cast iron heads rather than Aluminum.
roadblock69 is offline   Reply With Quote
Old 04-20-2013, 01:28 PM   #11
GOSFAST
CF Senior Member
Quote:
Originally Posted by plansch View Post
Hi,
Thx
Marcel
Hi Marcel, don't have the OEM documentation any longer but I can add some info here!
These units were available in the early 1980 era, they are not actually considered to be an LS-6, there wasn't any "LS" connotation for them. They were sold by G.M. as "pump-gas specials", being the basic LS-6 short block but with the cast iron "open-chamber" heads. The C.R was 10.2:1 and these came out as the result of the "gas-crunch" of the 1970's, it was a "best-seller" at the time!
They were sold w/o the intake manifold, exhaust manifolds, distrbutor, or any clutch.
Thanks, Gary in N.Y.
P.S. I believe they sold for about $2400.00/$2500.00 or there abouts, not 100% certain!
GOSFAST is offline   Reply With Quote
Reload this Page Tech Specs for 90' LS6 crate engine
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Deka 60lb injectors, 243 ls6 heads, FAST 90MM BAMNCO C5 Parts for Sale/Wanted 12 01-22-2014 08:44 AM
FAST LSXR Intake Manifolds on Special at RDP Dynosteve C6 Tech/Performance 50 11-05-2013 10:40 PM
engine parts off ebay? xomega C5 Tech 11 07-22-2013 12:41 PM
6L90 power rating kj217 C6 Corvette General Discussion 1 05-18-2013 01:57 PM
FS: NEW LS7 Engine Covers $90 shipped BaneZ06 C6 Parts for Sale/Wanted 2 10-23-2012 12:13 PM
Emails & Password Backup
Search Engine Friendly URLs by vBSEO 3.5.2
