80-82 dana rearend cap girdle
Just thought I'd share this with you guys.
I don't think anyone else has done this.
But maybe this helps the rear end cap survive.
Factory batwing with a girdle welded in.
Pretty slick.
I've thought of doing this myself. With the problems of the weak caps on the 80-82 Dana 44s, I'm surpised nobody has tried this before.
Belt and suspendors.
looks like a good cap.I need to beef up my 80 dana 44.I would like to put a locker insert into .I want to launch with slicks or DRs.I only have a 2500rpm stall .
Premium Supporting Vendor
Actually no. It's created such a boost in business I am having to hire people to get all the work out. But then I'm not using any imported junk parts in my rebuilds.
It also allows me to not explain why the stud won't work and all the problems it will create.
traccdogg2 do you sell steel caps for both sides ?they look great ! should I stick with the 40 dana ,or consider a rear from a c4 ?do you have steel caps for a c4 rear ?
Mike's steel cap mod works... then you will find the other weak areas in the differential!!!
Weird with the videos .. I have no opinion as no one knows but them 2 what happened.
