Brake system?????
Brake system?????
Hello Forum Folks....
Gotta quickie......Are there any known adjustment or tweaking procedures for a 78 coupe "proportioning valve"????
As always..thanks in advance for your help........
mk's78
Mike
mk's78
Mike
Received 2,878 Likes
Hi Mike,
I think the term 'proportioning' is a bit of a mis-name.
It's really just a 'distribution' block. It has no means of adjustment.
Regards,
Alan
Regards,
Alan
Alan is correct that the earlier C3 valves had no actual proportioning function as they did not require it, but later cars like the OP's did. In any case, the valve is not adjustable nor should there be a need to do so.
