New exhaust arrived today
#41
I ordered the true duels with magnaflo mufflers from cc on there ebay add and figured that I would get the tight tuck headers later on. I called cc yesterday and told them what I have and would the tight tuck headers work and they said that it wouldn't because the stock manifold was shorter than the headers and I would have to ship back the front pipes and get the ones that would work properly. I say this because you said that you were going to do this a little at a time . Hope this helps. Vince
#48
Took a little trial and error but fit ok. I want to thank all you guys for your input. The car is still up on jacks because I'm going to change the rear shocks.Can't wait to go for a ride. Weather is getting nicer everyday.
#56
Ok just about there. Front end rebuilt with the poly bushings,ball joints tie rods ,front shocks,etc . New exhaust in place. Now the rear shocks are on order along with new strut rods with rubber bushings. I figured I'll do the strut rods so I can get a true alignment. What do you guys think ?
#58
I used the supports that CC supplied with the exhaust kit. I installed them on the other side of the cross member. There was holes there already. Still tweaking the exhaust a little bit.
#59
Ok everything's in place .My next question is curved exhaust tips or straight one's? That should finish off the installation of the exhaust. Shocks are in along with the new strut rods. I will be posting pics over the weekend.
