Pcv valve question
Pcv valve question
Was going to replace the pcv valve on my base 350 engine '72, today. The valve at the parts store was the same size, but the top of it was straight. The valve I'm replacing has a black plastic T on the top and the ends of the T are 2 different sizes. When connected, there are 2 hoses coming off of the T. Do I take the T off of the pcv valve that I have and reuse it, or is there a valve with that T already attached? Parts guy was absolutely no help because it didn't show on his computer.
Duane
Duane
Received 2,878 Likes
Hi Dave,
The original pcv on my 71 has a short length of rubber hose that runs from one of the outlets on the plastic tee to the straight nipple on the pvc.
Will that work on yours?
Regards,
Alan
Regards,
Alan
I'm going to try and heat it to see if I can remove it and put it on a new one. If that doesn't work, I'll get a new T and do like Alan. Thanks for the suggestions.
Duane
Duane
