Click once when turning the key to start
Old 03-13-2013, 07:42 PM
kansas123
kansas123's Avatar
Default Click once when turning the key to start
I believe that maybe I should get my starter rebuilt (is it best to for the purposes of maintaining originality to rebuild?). When I turn the key, it might or might not just do a single click. Might do that 2 or 3 times, then it will hit and the car will start. Or it might start on the first try. I think when I was a kid, people used to say that it is caused by a flat spot on the starter or silenoid or some such thing. Never has failed me but one of these days.... Think it's the starter? Thanks.
Old 03-13-2013, 08:02 PM
63mako
63mako's Avatar
St. Jude Donor '08-'09
Might be a bad conection. Corrosion on the batt to starter wire. You can disconnect the starter wires one at a time, clean them and the posts with a wire brush, put some dielectric grease on them and reconnect. Same with the battery terminals. Will likely solve the problem.
Old 03-13-2013, 08:11 PM
kansas123
kansas123's Avatar
thanks I will give that a try, hate to think about removing that stupid thing, they weigh a lot more now than when I was a teen, ha ha.
Old 03-14-2013, 09:31 AM
surfertom
surfertom's Avatar
could also be the solenoid is on the way out it can be replaced separately but of course the starter would have to be removed. clean the connections first and if that doesn't solve the problem when the starter is out you can have it tested.
Old 03-14-2013, 11:22 AM
larrywalk
larrywalk's Avatar
Sounds like a worn contact disk internal to the solenoid. Just replace it, or if you like taking things apart, you can flip the disk to the unworn side.
Old 03-14-2013, 03:00 PM
7T1vette
7T1vette's Avatar
Received 2,717 Likes on 2,275 Posts
Bad solenoid is most likely the cause. The solenoid has the high current contacts in it; then it just sends power to the starter. It still could be the starter...but highly unlikely.
Old 03-14-2013, 07:57 PM
kansas123
kansas123's Avatar
Thank you all for the responses very much.
Old 03-15-2013, 12:22 PM
Camivette
Camivette's Avatar
This may be a good time to replace with a mini high torque starter and you can put your original on the shelf (low shelf, they're heavy) and you're done
To Click once when turning the key to start
Quick Reply: Click once when turning the key to start
