sbc vs bbc build price
Everyone has SBC parts and kits for a rebuild, cheap or should I say inexpensive, Then the BB, well it will take a little more $ but not much as its still plentifull and still not a ford
O yea I do own a 550hp classic stang,,, did I just say that
To make "big" power, the SBC needs aftermarket heads. Not so with a big block, there are plenty of factory castings that'll make 600hp without too much trouble. Differences in prices for parts is negligible. Buying all the stuff it takes to hang accessories is a good bit more expensive for the big block, though.
You gotta figure the big block "grins" into the equation - those that can't be wiped off your face when you either 1)open the hood to show your power plant, or 2) mash the loud pedal.
The power small blocks are throwing down for a cheap price is hard to beat and the weight savings is huge!
But if a cheap 454 lands in your lap, there's no replacement for displacement!
The machine shop doesn't car if its big or small block, it all about the same for machine work. Stock replacement parts, pistons, cam, bearings, gaskets, ect.... Are about 30% more and that's on the high side of pricing.
Received 3,043 Likes
St. Jude Donor '05
The BBC wil cost more but look what you get.
A sbc with the good stuff can make good hp but youll never get the brute torque you will with the cubes of the BBC and thats what makes a street car fun. hp/rpm motor get expensive real quick!!
If you were just shooting for 500 crank HP or less, costs will be similar, although maybe a bit less for the BBC since you can use stock heads, crank, rods... But you take the 150lb weight penalty...
If you are looking for more HP then that, the SBC build costs will shoot up high real quick...and a BBC becomes more cost effective.. This depending on the quality of parts you use, the rate the machine shop charges for machining and assembly and how much of it you do yourself.
A 600hp SBC will cost more then a 600hp BBC..
Remember you also have to factor in the conversion costs of the BBC stuff.. (Brackets, pullies, headers etc etc).
Cruise-In IX Veteran
Conversion cost is what gets you with a big block, especially if you do not have a complete big block to rebuild. I am working on doing a conversion on my 71, and only had a BBC block and crank to start with. I am looking at around 8-10K to build up a decent BBC engine that I want vs rebuilding a SBC for 2-5k. All the little stuff is adding up like radiator, pulleys, brackets, flywheel, balancer, etc. that are not usable from a 350 to a 454.
Stick it in your car and run 10s on pump gas.... DONE.
But yes, the BB brackets, pullies ext ext will eat your budget alive.. Not to mention the good water pump, better radiator...ext..
I did the conversion and its quite expensive.. But then again, a well built SBC that makes 600+ HP will cost you $10-12k so.... It's almost a toss up sometimes...
The big block is very streetable and can still run good ETs with highway gears and a tight converter.
much easier than a small block.
Get a dart based 427 SBC ,,, saves weight , no need to worry if something will bolt back on and it makes 610hp for under 8k .. And only needs 6300 rpm to hit max power .
Reason I asked this is b/c I noticed you can get a rebuilt 454 from summit done by atk for $3300 with a claimed 415hp and 497ft-lbs tq. One of the more popular crate engines is the year one 400+hp/tq vortec based 350. It seems doing a bbc conversion would net better gains. I would rather rebuild a used 454 to a 496 and reuse everything else. It can be done for similar price compared to the crate engine but with better internals.
You should have just picked up a Vortecpro 496" for $7800 shipped... They make between 650-680 HP and are very low maintenance..
A basic build using an engine kit with press fit forged pistons and recon on the rods and crank on each engine coupled with a good aftermarket carb, intake, and headers will yield you about 1HP per cube. So you are comparing 350HP to 460HP. Add heads and a hyd roller stick you can obtain 1.2HP per cube.
rebuilding a 350 makes no sense if you can make it a 383 for not a whole lot more, nearly everything from the original engine would be tossed out so its not a very cheap option. Ajrothm mentioned a 496 for $7800 shipped - sounds like a steal to me... as long as you keep stock tires all should be OK, when you start transferring power to pavement everything will give up and it doesn't matter if its a build SBC or BBC
I had the same experience..
I ended paying an easy $10,000 not including the EFI I added. As Alan said, it may be best to buy one already built from a pro engine builder who has his own shop. Shops can usually get all the parts much cheaper than what you or me can get them. On top of that we have to pay for all the machine work labor and what not...
I strongly disagree with the comment that there is hardly a difference in cost between building a BBC or a SBC. Things like the damper, rotating assemblies, lifters, rocker arms, valves, studs, valve covers, intake manifolds, headers, etc, etc, etc... They are cost more.. I would be willing to bet with just the parts mentioned there would be close to if not more than a $1,000. If SBC costs $10,000 to build, thats a difference of 10%.
If my goal was 500 HP with either a traditional SBC (gen1) or BBC, I would turn that 350 into a SBC 396 (4.03 w/ 3.875 stroke). You would have the ups of BBC such a HP, TQ, size, and you wont be burdened with the extra weight. Not only that, you can save money reusing some of the parts you already have.
Allow me to share a slightly different opinion. Be careful WHICH year Big Block you invest in. I just sold my 82 Camaro. I had a moderately worked 350 in it which was pushing about 350hp. (about 150 more HP than a stock setup) I had about 3 grand invested in the engine. (including initial purchase price of a stock, .030 long block) Nothing extreme, but it was a STRONG motor. Small blocks can make HUGE gains fairly cheaply. Heads, cam, exhaust and a carb can done for under 2 grand.
Now lets look at my 454....
270 HP from the factory. Are you kidding me?? (Its a 72 motor) OK, I get it, smog control choked the hell out of them, but 270??? Now what will it take me to get this engine to produce another 150 HP like I did with my small block? Carb, exhaust, cam,...AND....A set of heads...AND pistons.....heads ALONE will run me at least 2 grand.
So, my meager point is that while a 454 is a great starting point to compare to what a mild 350 will perform like...getting a stock 454 to 'perform' costs far more than a small block. Dollar for dollar, HP is cheaper with a small block.
Whatever you decide I'm sure you'll have fun with it but it sure brings a smile to you face when you open that hood and you see nothing but motor between the fenders with the BB.
we went from bubba braggin hp to "as installed" hp in 71....
