Best way to install a radiator, shroud, and lower hose
Old 02-18-2013, 06:50 AM
Dan H.
Dan H.'s Avatar
St. Jude Donor '17
Default Best way to install a radiator, shroud, and lower hose
I have replaced the front cross member and radiator support due to rust. When I removed the shroud to get the radiator out, it was a bear to put it lightly. I actually damaged some fins on the radiator pulling the shroud out. The lower rad hose is also very difficult to get on, once the radiator is in.
Is it easier to install all these as one piece? My thoughts were that the radiator itself was the biggest obstacle in getting the shroud out. So, I'm thinking the best way to get it back in is in one piece.
Any help here is appreciated
Old 02-18-2013, 07:13 AM
scottw
scottw's Avatar
I've always done the radiator w/ the bottom hose attached and then the shroud. Definately a job I don't like to do. Takes a lot of patients which I don't always have.
I've never tried it all at once. I think you would still have the problem of getting it to fit within the control arms.
Old 02-18-2013, 07:16 AM
diehrd
diehrd's Avatar
Your right with one piece ... Do it that way .
Old 02-18-2013, 08:40 AM
71scgc
71scgc's Avatar
Bud of mine cracked my shroud doing it piece by piece. Told him and told him, but what do I know....
Carter
Old 02-18-2013, 08:48 AM
7t2vette
The ORIGINAL and bestest
Support Corvetteforum!
7t2vette's Avatar
Toronto Events Coordinator
Assemble the support, rad, and shroud outside the car and then install it as a unit. Much easier that way! You will obviously need someone to help you do it this way.
Old 02-18-2013, 08:51 AM
mrvette
mrvette's Avatar
Have to remove 6 bolts and maybe bottom bolts holding the rad support, swing it forward, and remove the fan, at that point I think you can sneak that shroud out,
before you reinstall it, you need to cut the shroud on each side, forming two halves, top and bottom, you put two metal tabs on the top or bottom section, 4 on each side, making a sandwich with two tabs and one section two on each side, the overhang makes a slot the other section can slip home in, I use aluminum pieces for this job....done it to many a car.....many cars come like this already....
Old 02-18-2013, 09:08 AM
qwank
qwank's Avatar
I always remove the radiator then the shroud. you can get to the lower hose from under the car easily
Old 02-18-2013, 09:09 AM
pws69
pws69's Avatar
No need to cut the shroud - had mine out several times without cutting anything.
Old 02-18-2013, 09:40 AM
DucatiDon
DucatiDon's Avatar
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
If you try to do it as one piece, The shroud wont clear the control arm without pushing the support forward. The way I did it was to get the radiator in the car, then lift it and push it forward while slipping the shroud into place. Definitely not easy. And NOT a one man operation. Pushing the radiator support forward helps a lot.
The hose is easy to do after the fact. (And Im not sure that it will clear with the hose attached.)
Old 02-18-2013, 10:43 AM
1974ta
1974ta's Avatar
Default Shroud
My experience is that if you loosen the top 4 bolts on the support that it will swing out of the way just enough to squeeze the shroud in place. If memory serves me I had to wiggle the support back and forth some once I started to slide the shroud in place.
Do it on a very warm if not hot day so you can manipulate the shroud around the control arm. I had to use a large screw driver to get the last 1/4" or so.
Be careful and make sure the two studs at the bottom to not get caught and break off.
All this is done with the fan removed.
I had to lay underneath to see exactly where to use the screw driver as a "persuasion bar". Be careful and it will go. Use something like really thick card board to protect wherever you place the blade of the screw driver to gain leverage.
Mine went in with no damage but it did take some time to figure out exactly how to squeeze it in place.
Bill
Old 02-18-2013, 11:03 AM
drwet
drwet's Avatar
I just did my '79 last week. I have to assume the earlier cars are different because mine was a piece of cake. Shroud goes in first, then the rad, then fan blade, and finally the lower hose. Could probably put the hose in before the fan blade.
Old 02-18-2013, 12:30 PM
Dan H.
Dan H.'s Avatar
St. Jude Donor '17
Thank you for all the feedback gents
I already installed the rad support. Sounds like I need to either unbolt everything except the bottom two side bolts to swing it, or remove it completely and install as one giant piece. The one giant piece (support, rad, shroud) is an interesting approach. If no "persuasion" is required with this set up, I think I will opt for that one.
Anything has to be better than the way I removed it!
Old 02-18-2013, 01:24 PM
Belgian1979vette
Belgian1979vette's Avatar
Remove fan, put in support and shroud. Install radiator in between. You'll have to tilt it somewhat to get the lower hose of the rad by.
Old 02-18-2013, 03:47 PM
BKbroiler
BKbroiler's Avatar
No need to remove the rad support. Just tilt it forward. Remove the fan. Drop the rad and shroud in. All this is easier if the hood is off. I did this twice on my car.
Old 02-18-2013, 07:11 PM
TedH
TedH's Avatar
I have to pull the radiator/lower hose before the shroud. I'll put the shroud in first and then the radiator will slide along the edges of the shroud (in my '80 L48) when I install my new radiator.
Old 02-18-2013, 07:23 PM
69small block
69small block's Avatar
Default fan shroud
I tape a piece of card board to rad in front of fins to protect them during shroud removal this is on 69
Old 02-18-2013, 08:14 PM
'75
'75's Avatar
Best way I found is to remove the fan and shroud and install them in the attic, permanently. Then install an electric fan!!!!
To Best way to install a radiator, shroud, and lower hose
Quick Reply: Best way to install a radiator, shroud, and lower hose
