Swapping an 81-82 monoleaf into a 78-80: bolt right in?
Old 02-15-2013, 01:48 PM
Fast81
Fast81's Avatar
Default Swapping an 81-82 monoleaf into a 78-80: bolt right in?
Is it just a remove old/ replace with new operation ?
I'm stripping out my 81 and have found a local 80 that i would want to swap the monoleaf into along with my rear pumpkin (&3.54 gears)!
PS - I'm talking the entire rear assembly (monoleaf, pumpkin, carrier, etc)
Old 02-15-2013, 02:40 PM
MelWff
MelWff's Avatar
Received 1,814 Likes on 1,604 Posts
Looking at any vendors web site 80 to 82 are the same
Old 02-15-2013, 03:44 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
You've confused me. Everything under your 81 is bolt up for 80 and 82. None of it is bolt up for 79 and earlier cars.
Old 02-15-2013, 04:36 PM
diehrd
diehrd's Avatar
Old 02-15-2013, 06:57 PM
Fast81
Fast81's Avatar
OK - guess i wasn't clear.
Found an 80 (to replace my burned 81) with the gymkana 9 leaf and a stock rearend.
I want to swap in the entire rear assembly (carrier, pumpkin, monoleaf) from my 81 chasis over to it to upgrade it to monoleaf plus the rebuilt rear with 3.54 gears.
Is this plan a straight ahead bolt swap ? Consensus seems to indicate "YES"
Is this right ?
Old 02-15-2013, 08:58 PM
gbvette62
gbvette62's Avatar
Received 2,018 Likes on 1,309 Posts
I think what was confusing people, was that your title said swapping an 81-82 monoleaf into a 78-80 car.
Since your post clarifies that it's actually an 80, that you want to swap a complete 81 rear into, then yes, as others have said, this swap will work.
80-82 rears are all identical, and completely different from 79 and earlier rears. Though all 78-82 Corvettes, equipped with steel springs, use the same 2 1/2" wide spring. 77 and earlier springs are 2 1/4" wide.
Have I completely confused you now?
Old 02-16-2013, 10:29 AM
Easy Mike
Easy Mike's Avatar
OK - guess i wasn't clear. Found an 80 (to replace my burned 81) with the gymkana 9 leaf and a stock rearend. I want to swap in the entire rear assembly (carrier, pumpkin, monoleaf) from my 81 chasis over to it to upgrade it to monoleaf plus the rebuilt rear with 3.54 gears. Is this plan a straight ahead bolt swap ? Consensus seems to indicate "YES" Is this right ?
That works.
Old 02-16-2013, 02:16 PM
mikem350
mikem350's Avatar
Remember if your ratio changes your speedo will be off too
Maybe get the tailshaft speedo gears from the donor car
To Swapping an 81-82 monoleaf into a 78-80: bolt right in?
Quick Reply: Swapping an 81-82 monoleaf into a 78-80: bolt right in?
