new coil springs are shorter
i ordered new coil springs on line for my 69. they are about 2 inchs shorter than the old worn out ones i removed. is this normal , they tell me that they are the correct part # for my vette. has any one had this problem before --- will they work thanks all
jerry
St. Jude Donor '09
You will appreciate the shorter springs when you put them back in. The original springs were a PITA to get in. The new ones went right in with no effort and no compressors. Mine were 550# and several inches shorter.
FWIW the aftermarket 550# springs are a very close match for the factory heavy duty suspension options. In some cases, virtually identical. The 460# aftermarket springs are the same spring with 2-3 extra coils.
I just did my 82 with moog springs. It was about a 4 inch difference in height on the bench but installed they were the same height
They must be indexed in the spring pockets correctly or you will see about an inch difference in height
