Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-12-2013, 09:12 PM   #1
Team Rockfish
Junior Member
tem rockfish
Default Auto to Manual Conversion
I was going to be buying the complete conversion kit from Keisler to get rid of the automatic tranny and install the Tremec.
Has anyone run into problems doing this?
I have two specific questions.
I have a ZZ4 series engine in the car and would having headers with sidepipes be in the way of the bellcrank or linkage?
Second, does the dash need to come out to install the new pedals?
Team Rockfish is offline   Reply With Quote
Old 02-12-2013, 09:16 PM   #2
Priya
CF Senior Member
If need be you can get a hydraulic clutch linkage from Keisler to avoid any header problems but I think you should be able to get headers that fit with the stock mechanical clutch linkage.
Priya is offline   Reply With Quote
Old 02-12-2013, 10:13 PM   #3
Shark Racer
CF Senior Member
Shark Racer's Avatar
Send a message via ICQ to Shark Racer Send a message via AIM to Shark Racer
I see you have a 78, I just did this last summer.
To change the pedals you'll have to remove the column, brake booster and gauge cluster.
It's not horrible as long as you're methodical.
Click the image to open in full size.
That's as bad as it gets. I took the time to clean up some wiring that had been hacked by previous installers and also cleaned up some of the rusty stuff under there. Good time to lube the speedo cable, check all of your bulbs, fix your clock, etc.
I posted a thread on this a couple months back and if I remember when I get home tonight I'll link you back to it.
Shark Racer is offline   Reply With Quote
Old 02-12-2013, 10:23 PM   #4
Team Rockfish
Junior Member
tem rockfish
Thank you much!!! appreciate your effort
Old 02-12-2013, 11:21 PM   #5
Team Rockfish
Junior Member
tem rockfish
Quote:
Only thing is it's had the headers since the engine swap so I guess we'll find out about clearance once the tranny sway begins.
Old 02-12-2013, 11:54 PM   #6
Team Rockfish
Junior Member
tem rockfish
How many hours do you think it took you to do the pedal install and get everything back together?
Old 02-13-2013, 12:22 AM   #7
Shark Racer
CF Senior Member
Quote:
If your goal is to just do the pedal swap, you can get it done in a day.
Make sure you have new pedal bushings, I replaced those, the spring, descaled the box and put a coat of paint on it.
Here's my thread:
http://forums.corvetteforum.com/c3-g...-pace-car.html
Note how I organized everything, real critical for this.
To do the shifter, you're going to have to have the center console off and you'll need to cut a hole in the floor, and come up with a way to cover the hole. Keisler sells a kit for that I believe.
You'll also have to figure out a clutch safety switch or neutral safety switch if you're interested. I used the neutral switch wire on the TKO but set it up as a feed to a relay. My 78 will only start if the shifter is in neutral.
Old 02-13-2013, 08:50 AM   #8
tom00799
Junior Member
Support Corvetteforum!
I'm doing this conversion as we speak. I bought the Keisler RS 500 instead of the Tremec. I went with the hydraulic clutch set up to avoid the hassle of welding a ball to the frame for the clutch linkage. I have sand rails with hydraulic clutches and they work great. The hardest part of the swap is removing and reinstalling the pedal assembly. You need to remove the steering column which is not to hard. I'm not sure that you need to take the dash completely apart but in my case I removed the entire dash because I'm re-wiring and installing Vintage air. The Keisler kit comes with what you need to convert the pedal assembly which is fairly simple. The kit does not include the plastic bushings so order those ahead of time. I also replaced the brake switch since everything was apart. The kit does not include a clutch alignment tool. I don't know why they don't include it. I guess they save four bucks. Do not use a universal alignment toll. They're worthless. My kit came with the Quicktime bellhousing and the fit is tight so the clutch alignment has to be dead nuts on.
tom00799 is offline   Reply With Quote
Old 02-13-2013, 09:56 AM   #9
qwank
CF Senior Member
qwank's Avatar
If the headers are made for C3 Corvettes, they will most likely clear factory clutch linkage
qwank is offline   Reply With Quote
Old 02-18-2013, 12:40 AM   #10
Team Rockfish
Junior Member
tem rockfish
Quote:
The ball has to be welded to the frame, it's not a bolt on deal?
Old 02-18-2013, 11:16 AM   #11
drwet
CF Senior Member
drwet's Avatar
If you get the '80-81 bracket its bolt on. The earlier ones were weld on. I bought a bolt on one for the conversion I'm doing on my '79 but I'm thinking about making one from heavier steel - some on this forum have said the stock ones are flimsy and will flex, making the clutch mechanism sloppy.
drwet is offline   Reply With Quote
Old 02-18-2013, 11:35 AM   #12
commander_47
CF Senior Member
I did some work on my trans tunnel as well. When the auto shifter is removed, there is a rather large indentation.
I flattened all that out, cut the hole to size, and welded in some new metal. Stock rubber boot and all wiring looks good. Took some work though.
commander_47 is offline   Reply With Quote
Old 02-18-2013, 12:59 PM   #13
DucatiDon
CF Senior Member
DucatiDon's Avatar
Pics of the hydraulic clutch master install?
How do you like it?
Im looking at doing the same for my Pace Car...
What other hurdles besides a different clutch and starter, and cutting a hole in the Tunnel?
DucatiDon is offline   Reply With Quote
Old 02-18-2013, 01:32 PM   #14
aaroncorvette
CF Senior Member
Hi mate, haven't seen it mentioned although I may have missed it?
Does your block have the threaded hole for the linkage ball thing?
aaroncorvette is offline   Reply With Quote
Old 02-18-2013, 03:13 PM   #15
tom00799
Junior Member
Here's pics of the hydraulic clutch set-up.
Old 02-18-2013, 06:00 PM   #16
commander_47
CF Senior Member
Some pics of the bolt on bracket on my 81. And more pics of how I did the tunnel.
Hope it helps.
Old 02-18-2013, 08:10 PM   #17
Shark Racer
CF Senior Member
commander 47 - did you weld in a new plate for the tunnel?
Quote:
How do you like it?
My conversion was on a pace car as well.
Are you starting with a manual? (the "different clutch and starter" part of your question threw me off.)
If you're starting with a manual, the TKO 500/600 will pretty much bolt in if you get one with the right housing (Keisler, American PowerTrain and others). You'll need a crossmember adapter and a new driveshaft.
If you're starting with an auto, you can likely re-use your starter, but you'll need to fabricate a plate. The 78 floor pan has a different setup for autos than manuals, and they don't play nicely. I don't know about later years, but earlier years the floors were the same.
Old 02-18-2013, 08:24 PM   #18
MIKE80
CF Senior Member
MIKE80's Avatar
As another option, you could pick up a T56 6 speed if you don't mind doing a few mods and cutting the tunnel for the shifter location. Here's a thread I did on mine.
http://forums.corvetteforum.com/c3-t...gs-list-7.html
MIKE80 is offline   Reply With Quote
Old 02-18-2013, 08:26 PM   #19
Shark Racer
CF Senior Member
Honestly after doing my TKO I wish I'd just done the T56, as I had to cut the floor anyways.
Old 02-19-2013, 03:02 PM   #20
commander_47
CF Senior Member
[QUOTE=Shark Racer;1583158780]commander 47 - did you weld in a new plate for the tunnel?
I didn't weld in a plate. I know some guys to that.
There is a large indentation where the automatic shifter goes. Unfortunately I do not have a good before picture.
I used my hammer and body anvil to beat the indentation up. Because the metal had been stretched to create the bulge, I cut a slot to remove the extra metal and make it all nice and level.
Then I welded the seam together.
After all that work, you still have to enlarge the hole for the four speed.
I made a cardboard template and cut the hole to stock specifications and it all fit together perfectly.
I will say something else that was a real PITA. I dropped the motor and trans in together.
You will never get the new trans in this way with the crossmember in place.
You have to bring the cross member up, with the linkage attached to it.
Once it's all up, you cannot place the little tool in the shifter to adjust the forks.
If I ever were to do this again, I would try to bring the tranny up with the crossmember and linkage already attached and adjusted. Not sure this is possible.
But I'm just one man in my home garage. I don't have fancy lifts or anything.
Reload this Page Auto to Manual Conversion
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
