oil pressure
oil pressure
has anybody seen this when under hard acceleration my oil pressure drops down to 50 to 60 pounds and then goes back up to 80 when i let off the gas usually does it on take off when i shift at high rpms into second gear any thoughts 6000 miles on rebuild pickup is welded to pump and has new sending unit
Stock pan, modified, etc? Sure it is full? Have you tried adding a 1/2 quart additional oil?
Might be aeration.
