Auto to Manual Conversion
Old 02-19-2013, 06:23 PM
Shark Racer
Support Corvetteforum!
Shark Racer's Avatar
Not sure what you mean by adjusting the forks. I ran mine through the gears before installing it and no adjustment was required, but I installed an AP TKO.
Old 02-19-2013, 06:59 PM
commander_47
commander_47's Avatar
QUOTE=Shark Racer;1583166708]Not sure what you mean by adjusting the forks. I ran mine through the gears before installing it and no adjustment was required, but I installed an AP TKO.[/QUOTE]
I guess I used the wrong terminology. Bikes are more my specialty, this vette is my hobby.
The shift linkage. You are supposed to put a little metal block under the shifter, and through the slots to hold the stick in neutral while you attach the linkage rods to the tranny.
This keeps the stick from moving and giving you a sloppy shift.
Quick Reply: Auto to Manual Conversion
