Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 02-09-2013, 12:41 PM   #1
BIGJIM13
CF Senior Member
Default Steel Brake Line Repair - Rubber hose?
Have a break in the brake line that runs from the front to rear drivers side on a 80 - can the rusty section be replaced with a piece of rubber hose without issue?
BIGJIM13 is offline   Reply With Quote
Old 02-09-2013, 12:54 PM   #2
'75
CF Senior Member
'75's Avatar
No, you need to either replace the whole line or splice in a piece of brake line to replace the bad part.
'75 is offline   Reply With Quote
Old 02-09-2013, 01:12 PM   #3
leadfoot4
CF Senior Member
leadfoot4's Avatar
Quote:
This is a trick question, Right??
leadfoot4 is offline   Reply With Quote
Old 02-09-2013, 02:10 PM   #4
dtamustang
CF Senior Member
only if you want to turn 5 or 6 big pieces of fiberglass into a 1000 little ones
dtamustang is offline   Reply With Quote
Old 02-09-2013, 02:31 PM   #5
ShefmonC3
Junior Member
ShefmonC3's Avatar
Front line runs to left and right front, rear line runs to left and right rear...
ShefmonC3 is offline   Reply With Quote
Old 02-09-2013, 02:32 PM   #6
Scottd
CF Senior Member
In a matter of days the brake fluid will swell the rubber and your repair will fail. Replace the damaged section with new lines or a compression fitting. Despite common belief, compression fittings work fine on brake lines.
Scottd is offline   Reply With Quote
Old 02-09-2013, 03:27 PM   #7
leadfoot4
CF Senior Member
leadfoot4's Avatar
Quote:
Scott, are you serious?? A brake line is a hydraulic line. Never mind the swelling from the brake fluid, one slight application of the brake pedal will blow off a "rubber hose patch"...
BTW, were you able to get the body centered on your chassis?
Old 02-09-2013, 03:33 PM   #8
FKING1
CF Senior Member
FKING1's Avatar
In-Line Tube sell replacement steel brake lines for ur car.
Bought one for my 70 drivers side front to back.
Wrks fine.
FKING1 is offline   Reply With Quote
Old 02-09-2013, 03:37 PM   #9
gcusmano74
CF Senior Member
NO.
A rubber hose has not the slightest chance of working. A hard stop requires something like 2000 to 2500 psi of hydraulic pressure. The hose is probably safe for maybe 1% of that.
gcusmano74 is offline   Reply With Quote
Old 02-09-2013, 03:59 PM   #10
stpman
CF Senior Member
stpman's Avatar
Quote:
Originally Posted by gcusmano74 View Post
NO.
NEVER use rubber line for brakes
stpman is offline   Reply With Quote
Old 02-09-2013, 10:08 PM   #11
garygnu
CF Senior Member
garygnu's Avatar
maybe with alot duck tape wrapped around it .seriously NO !
garygnu is offline   Reply With Quote
Old 02-09-2013, 10:39 PM   #12
72LS1Vette
CF Senior Member
72LS1Vette's Avatar
In Mass. compression fittings on a brake line are not legal and rubber lines are certainly not legal. New lines or flared couplings are the only options here.
Rick B.
__________________
72 Ontario Orange Coupe. 2001 LS1 - LS6 block & Intake, Thunder Racing Cam, Ported heads and Throttle Body, Meziere electric water pump, Hooker Shorty Headers, 2001 T56 6-speed trans, VB&P Street & Slalom suspension, Magnaflow exhaust, DeWitt's radiator, SPAL fan, C5 power seats. Future mods: HydoBoost, Borgeson steering box, floor mats.
72LS1Vette is offline   Reply With Quote
Old 02-10-2013, 08:22 AM   #13
7T1vette
CF Senior Member
7T1vette's Avatar
All you guys know that each of the brake calipers has a rubber line connecting it to the steel line....right? Now, I'm not recommending that this be done for the problem you have, but there are rubber lines that are made to handle high-pressure fluids. As long as you use the correct type of flex line, it would be OK.
But, you would be much better off with repairing a section of steel line with some good-quality compression fittings [if legal] and a new piece of steel tubing. Or, you could go with flared ends on the tubing and AN type [union] fittings.
7T1vette is offline   Reply With Quote
Old 02-10-2013, 08:34 AM   #14
diehrd
CF Senior Member
diehrd's Avatar
Just replace the line with a correct steel replacement. I mean your talking about stopping the car which is its biggest priority don't ya think...
diehrd is offline   Reply With Quote
Old 02-10-2013, 02:27 PM   #15
dtamustang
CF Senior Member
the flex lines are hydraulic hoses with crimped hydraulic fittings,there is no way any amount of hose clamps will even come close to holding.as far as i know an average stop generates about 2000-2500 psi, a panic stop goes to 4500 psi +.
Old 02-10-2013, 02:57 PM   #16
stpman
CF Senior Member
stpman's Avatar
Quote:
and to add to that to use a rubber "brake" hose you have to put a proper flare and splice coupling so just use the steel line.
as said above if you were to check you'll probably find that it's not legal in more states/provinces than just Mass
if you like I can show you a pic of my avatar Z28 after the brakes failed and the PO rear ended a dump truck, not worth it
Old 02-10-2013, 03:07 PM   #17
Garys 68
CF Senior Member
For less than $10 you can buy a short piece of brake line and SAE fittings. You need a double flare tool but you can splice in a piece.
I'm going to assume when you said rubber hose, you meant a brake hardline to caliper hose. That would be more expensive and complicated than splicing in a harline piece.
If you dont know the difference between seamless/non-seamless brake line, SEA, inverted flare, and JIC/AN fittings, single vs double flare, have someone who does do it.
Garys 68 is online now   Reply With Quote
Old 02-10-2013, 05:05 PM   #18
leadfoot4
CF Senior Member
leadfoot4's Avatar
YES, we know that.... but those are "brake hoses", specifically designed for hydraulic pressure. The OP simply said "rubber hose", and most of us assumed he meant some garden variety piece of rubber hose, as a patch. Maybe he did, maybe he didn't....
Old 02-10-2013, 06:10 PM   #19
68-427Rich
CF Senior Member
68-427Rich's Avatar
Replace the entire line, you'll probably need two pieces of line with a brass, inverted flare union.
$10 or less for the materials.
68-427Rich is offline   Reply With Quote
Old 02-10-2013, 07:57 PM   #20
7t9l82
CF Senior Member
7t9l82's Avatar
i agree under no circumstances unless you are fixing my ex wifes car should you use a rubber hose. if it is for her leave the clamps loose too.
7t9l82 is offline   Reply With Quote
Reload this Page Steel Brake Line Repair - Rubber hose?
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
