Changing out turn signal lever
Okay, so I bought a '79 Vette and the works begins now. The lever for directionals and the high beams doesn't seem to be working since I don't have turn signals or high beams. Initially the high beam worked but then the lever wouldn't click into position. The turn signals also failed at about the same time. Hazards are also not working. Looked over the fuses and they look fine. So that leads me to the what's going on in the steering column. I've seen a couple of posts online for pulling this thing apart and I'm wondering if it's really a job for a novice. Thoughts or suggestions?
Does the turn signature lever "click" normally, or does it spin in the pivot hole?
Turn signals not working could be the switch, bulbs out, fuse (did you do a continuity test?), or flasher. I'd check bulbs, fuse, and flasher before tearing the column down to replace the switch.
The high beams are a different switch, and it could be that the switch has failed or was poorly adjusted.
Go to corvettefaq . com and look up Jim Shea's papers for an idea how this all works.
It sounds like it might be a bad turn signal switch to me.
There were 2 different turn signal switches used in 79. One was used in all 79's with the standard straight column, as well as early 79's, with a tilt/tele column. The other switch was used in later 79's equipped with a T&T column. If you have a tilt column, you can identify which switch you need, by the turn signal stalk. If you have a bent turn signal stalk, you have the early 79 style switch. If your stalk is straight, you need the later, or second design switch.
It's not a terrible job to change the switch, but it is a little easier, if you don't have tilt. The Corvette shop manual gives step by step instructions, on how to replace the switch.
The dimmer switch is incorporated into the turn signal switch, on the OP's 79. 76 was the last year that Corvettes used a floor mounted dimmer switch.
The dimmer switch is on the column and actuated by a rod when you pull back(towards the driver) on the turn signal lever.
I just did this job last year. It sucked. Take the column out of the car if you're going to do it. It is NOT fun to do in the car. I think I may have shed a few tears in the process...
If you look at this photo, you'll see the pivot (aluminum, retained with roll pin) and the black plastic part of the pivot. When you pull back on the pivot it pushes the yellow piece in and actuates the dimmer switch. Turn signal switch has already been removed and is covering this mechanism. To get the switch out you either have to cut the wires in the column or disconnect them from the harmonica.
To do this job, you'll need a turn signal switch and a plastic lock plate retainer ring.
I got my parts from Willcox, and Willcox has a good walkthrough on it.
Yea, the pivot or at least the sitting of the lever in the pivot is an issue I need to tackle. The turn signal switch is bad and needs replaced but I also will need to deal with the pivot. Obviously it isn't part of the whole turn signal switch so...going to get parts and whatnot today to see what I can do about this.
The high beams worked initially now it doesn't click backward to tien them on which is obviously the pivot. Turn signals move up and down but no longer turn on the signals. Hazards never worked. Got what I need to work on our now just need to get time.
Let's take things one at a time. First of all, I think that you have a tilt & telescoping steering column. By 1979 I am quite sure that T&T columns were standard by that time.
Your turn signal lever plugs into a part of the T&T column called a dimmer pivot. When you pull the turn signal lever toward you, that mechanism pivots and depresses a rod that reaches down and actuates the dimmer switch on the side of the steering column, (down under the dash.) When you pull on the TS switch lever, you should hear and feel a sharp click as the dimmer switch changes from high to low to high beams. There is a slight amount of adjustment of the dimmer switch available where it attaches to the same stud that holds the ignition switch. Be careful, you don't want to disturb the ignition switch adjustment.
Now that same dimmer pivot connects to a crossover arm that is attached to your turn signal switch by a single screw. It is possible that the screw is loose or missing.
There should not be a difference in the turn signal switch with straight versus bent turn signal levers. There are different pivots that dictate a straight versus bent lever.
This is sort of a busy picture. But at the lower position you should see the turn signal levers. The one on the left is attached to a dimmer pivot with a 21 degree 30 minute angle. The one on the right is at a 46 degree 30 minute angle. The first one would take a bent lever, the second would accept a straight lever.
Jim
Jim
Jim,
I have an early model '79 and it doesn't have the telescopic steering wheel but I don't believe that will make a difference as far as what needs to be done. In fact, I believe the telescopic steering wheel is actually harder to deal with than the tilt only wheels.
Jim,
* Tilt & Tele
* Non-tilt, non-tele
When I first had my 78 I used to think it was tilt-only as well. There's a locking ring just behind the horn cap, move it to the left. Telescoping wheel.
Sorry that I jumped to a conclusion on your steering column being a T&T. FYI, Corvettes never had a tilt column only. It was either a telescoping only column or a non-adjustable type from 1965 through 1968. And it was a Tilt & Telescoping type or the non-adjustable type from 1969 through 1979. It has been the T&T type ever since.
The standard non-adjustable steering column in your 1979 Vette also has a crossover arm that reaches from the dimmer pivot to the turn signal switch. It is not the same arm as the T&T type. So you still could have a problem with the connection of the arm to the TS switch.
Jim
Jim
For what ever it is worth way back when I figured out that the 1981 Turn signal stalk could replace the original in my 1980. This was long before the internet. Anyway, by doing so the Cruse Control gets the resume feture, with no other Mods. It would probably work on at least the late 79 stalk.
Lol okay so it is telescopic! I love this forum, I'm learning so much ha ha ha! Tomorrow I'm going to start working on the switch. I will keep everyone posted as I'm sure I will have questions.
Signal lever question
I just got a 79 with tilt T&T and the turn signal lever spins around in the column. what do I need to replace to have the lever stay in the correct position, it has a 30 degree bent to clear your legs,. thanks, AL.
Dimmer Pivot
Okay, figured it out anyone needs information I have it.
Resurrecting an old thread here. I have a 78 with tilt/telescopic wheel. My turn signal arm broke off at the end. So it still works fine, been like this for months. I was under the impression that I had to take the steering wheel apart, so I haven't done all that. I've been doing some reading that maybe I can remove and replace this turn signal arm? If that's true can someone give me a little guidance? Thank you, Merry Christmas guys.
Doug1 (12-25-2018)
Thank you though.
Oh how I wish you would have posted your fix!
My turn signal lever spins in the column too - 1981 T&T corvette. What was the fix?
I am at corvette1981@yahoo.com
Thank you so much!
Thank you so much!
