Try HHO, Water plus Baking Soda=Hydrogen Gas
I've installed an HHO system on my 1969 427/435 4 speed. Essentially it's a "Brown's Gas" setup that makes hydrogen gas which either goes into the carbs at idle or the intake manifold at cruising. The hydrogen is made by mixing baking soda with distilled water and putting an electrical charge on it. I've been running this setup for over four years and average 16-17 mpg general driving. The car used to get 10 mpg or worse. I'm also able to run very nicely on regular unleaded gas. I heard about this one night while listening to talk radio. Some guys from "Water4Gas" were and it sounded too good to be true. I bought a kit on ebay for under $100 and hooked it up. It took less than an hour and as soon as I fired up the engine, it ran smoother and you could feel the additional power. My particular car takes 3/4 teaspoon baking soda to one mason's jar of distilled water. I've got a two jar kit. Every three to six months, I have to clean the jars and replace the water and baking soda. I'm on my second set of "coils". I wish the car would get 30 mpg but frankly 16-17 mpg is better than it was before. The car will ping a bit under a load in fourth gear going up a hill and even if I use super, it still does. It did ping before the HHO using only super and it pinged more then than it does now. Do a search on youtube for "HHO" or "water4gas" or "Brown's gas" and see what these guys have done. It really does work. You can go to my account and look at my recent post by "fontking1a". It's called ...."I'm Back". There are pictures of the car with the HHO installed.
Lookie there we have ourselves a "Green" big block .. But do you really think your making enough hydrogen from that mix to affect anything ? I doubt it 100% ,, you can never ever ever ever get more energy out then you put into making it unless you invent fusion drive making all you posted pure hype.
Uhh no
If you believe in this system, you are an idiot. Sorry, I cannot euphemize this one for you. You are an idiot. You are a monkey that's learned how to use a keyboard. You occasionally forget to breath. You wear a bib to catch the drool.
You're a moron.
The electrical energy you're using to split the water molecules into hydrogen and oxygen gas is MORE THAN the energy released when you put them back together. This is how the world works. Everytime energy changes forms, you lose some of it. Nothing is free. The effective efficiency of Bubba's mason jar electrolysis will probably be 50-60% at best.
Physics courses are not required to receive a high school diploma in most American schools. I take issue with that.
You're a moron.
I came across this test. Let us know how you make out.
If you're someone who's certain that you're getting improved mileage from your HHO system, here's an experiment for you to try...
First, make sure you can turn your electrolysis cell off and on while driving.
Now with the cell turned off, drive at a constant 60mph for a minute or two, so that the engine reaches a steady temperature. Don't use cruise-control, just use your foot to position the gas-pedal so your speed remains constant.
Without moving your foot (the one on the gas pedal), turn on your electrolysis cell.
Now if all the claims for HHO are true, your engine will be developing 20%-30% *more* power than it did with the electrolysis cell turned off -- so you should notice your speed increase to around 70-75mph as the HHO gas starts flowing.
If you don't get this increase, then it's *not* working.
Or you could do this the other way...
Ensure your electrolysis cell is energized and drive along at a steady 60mph.
Now turn off the cell without moving the gas pedal up or down.
Your engine's power should drop noticeably -- since the combustion efficiency will now be much lower than before. This means your car should slow down quite noticeably -- perhaps to as little as 45mph.
Here's a question -- does your engine's idle increase by 40% as the HHO gas starts being generated after you start it? If not -- why not?
If the fuel is burnt 40% more efficiently then the amount of fuel that produces an idle of (say) 1,000 RPMs should produce an idle of 1,400 RPMs when the gas kicks in. If it doesn't then there's your proof that this system doesn't work.
To prove or disprove your system, run it out of fuel, try running it solely on hydrogen, disconect the fue pump. I do know that you can make hydrogen this way, but dont beleave enough to have any effect on mpg. For better mpg you should off set your fuel economy wyith a scooter.t
Not to play devils advocate here.....BUT,
We have installed a system on large OTR trucks and done MANY MANY miles of documented testing. Same trucks, same drivers.....on existing trucks.
City mileage increase was negligible but average OTR mileage did INCREASE 8-10% consistently.
It is all about proper sizing ans use.
FLAME ON!
LOL
FLAME ON!
LOL
FLAME ON!
LOL
FLAME ON!
LOL
Uhh no
If you believe in this system, you are an idiot. Sorry, I cannot euphemize this one for you. You are an idiot. You are a monkey that's learned how to use a keyboard. You occasionally forget to learn to breath. You wear a bib to catch the drool.
You're a moron.
You're a moron.
It is possibly to release more energy from this sort of concept than just that which is input from the electrical power based on energy released from a chemical reaction, but that doesn't apply in this case. The baking soda essentially is the salt of an electrolyte solution.
If it works so good how come California hasn't voted this hocus pocus into state law for all emission producing motors?
Water4gas is the scientology of engineering/physics....
Sorry if that insults any scientologist.
Doesn't this belong back in "off topic" under politics or something?
squirrels
I tried HHO but it did not perform very well. I changed over to two squirrels in a wire wheel. I do not run them all the time...only when I need a little extra power. They kick in when I hit the switch that charges the wheel with a light electrical impulse. They do require high octane peanuts and you do have to clean the wire cage wheel a couple times a week. Patent pending.
Its not some thing for nothing, we made hydogen this way in high schooln but used an arc welder for the current, it made hydrogen alright but the rate with a welder was slow enough that it would take a day to build enough to go a mile, then you would still have to compress it and store it for it to work as a fiable source.
Wait just a minute now! Are you guys suggesting that someone on "talk radio" was full of BS ?!?! That is just un-American.
http://green.autoblog.com/2008/07/18...er4gas-system/
Andy
