I need to work out the little details timing cover, distributor gear, pushrods, etc
Old 01-31-2013, 12:05 PM
TimberwolfFXDL
TimberwolfFXDL's Avatar
Default I need to work out the little details timing cover, distributor gear, pushrods, etc
My car has a later model 880 block that's setup for roller cam, but has a flat tappet version in it now. I'm swapping on vortec heads with .015 gaskets, a roller cam (XR276HR I think), 2400-2800 stall tq converter, performer rpm intake and holley carb. Also upgrading the fuel pump (still mechanical).
my questions:
when I buy the new timing set, should I get a torrington bearing or bronze thrust bearing style?
Am I going to need a different timing cover for a double roller timing set?
Do I need to swap out the gear on my distributor?
Stock length pushrods ok, even if I use some harland sharp roller rockers?
Anything else in the details I need to be aware of for this swap?
Old 02-01-2013, 08:03 AM
TimberwolfFXDL
nobody?
Old 02-01-2013, 08:44 AM
diehrd
diehrd's Avatar
I may be wrong ,, but if it is a 1 piece rear seal block it is ready for a roller cam . A late model dist will have the right gear and a double roller set will fit behind a stock timing cover
Old 02-01-2013, 11:02 AM
TimberwolfFXDL
any thoughts on pushrod length?
Old 02-01-2013, 11:09 AM
diehrd
diehrd's Avatar
I dont have any, but search push rod length see what that gives you
Old 02-01-2013, 11:13 AM
63mako
63mako's Avatar
St. Jude Donor '08-'09
You will need to use a pushrod length checker to establish correct length. Check intake and exhaust.
Likely need a melonized dist gear.
You use a step nosed cam and the factory lifters, retainers and a double roller timing set is fine.
Old 02-02-2013, 09:09 AM
diehrd
diehrd's Avatar
Here is one in the used parts area
http://forums.corvetteforum.com/c3-p...h-checker.html
Old 02-02-2013, 09:19 AM
71scgc
71scgc's Avatar
Or you can get it from Summit for $20
Old 02-02-2013, 09:26 AM
diehrd
diehrd's Avatar
Ha really !! Well there you go being as i had no idea on value I thought i was helping he he he
Old 02-03-2013, 08:31 AM
surfertom
surfertom's Avatar
i don't think summit ships for free or throws low tension valve train checking springs in for free either. new total from summit 27.90. j guess i was out of line asking $30.00 for my stuff. thanks 71scgc for pointing that out.
To I need to work out the little details timing cover, distributor gear, pushrods, etc
Quick Reply: I need to work out the little details timing cover, distributor gear, pushrods, etc
