How Do I REMOVE My SB Crank Gear? Tool?
Old 01-23-2013, 07:38 PM
TedH
Support Corvetteforum!
TedH's Avatar
Default How Do I REMOVE My SB Crank Gear? Tool?
Thanks for all of your help identifying the tools for installing my crank gear on another thread. From that exchange, I've identified tools that:
  • Install Crank Gear on crankshaft
  • Install/Remove damper on crankshaft
But, none of them seem to ALSO pull the crank gear. I have a pitman arm 'jaw' puller for my '80 L48.
Will it pull my crank gear?
Old 01-23-2013, 07:56 PM
RPOZ4Z
RPOZ4Z's Avatar
Cruise-In VII Veteran
you need a 2 or 3 jaw puller... I just removed mine with a 2 jaw puller with no problems.
Old 01-23-2013, 09:22 PM
TimAT
TimAT's Avatar
Either a 2 or a 3 jaw puller will work fine- just put something in the end of the crank so the pressure screw on the puller can't get deep enough into the taper to either get stuck or damage the threads.
Old 01-23-2013, 09:36 PM
Learning_Curve
Learning_Curve's Avatar
You can use one or two 1/4 drive deep sockets and put them in the end of the crank. Bubba, maybe. But it works and you most likey have them handy.
Old 01-24-2013, 05:47 PM
69ttop
69ttop's Avatar
get a bolt without a washer and simply screw it all the way in the end of the crank so the center puller screw will turn on the bolt head.
Old 01-24-2013, 06:22 PM
iokepakai
iokepakai's Avatar
Just did this for my roller cam swap.Remove gear with 2 jaw puller and an oversized washer over the crank snout ,as not to damage threads in crank.Installed gear by using a large diameter PVC pipe over the crank and tapping evenly on the pipe pressing the gear on the crank.Use a Harmonic Balancer installer tool,to press balancer on to crank.If you use the balancer bolt you risk the chance of pulling out the crank threads.
[IMG][/IMG]
Write up of roller cam swap in the works....
Old 01-24-2013, 06:23 PM
'75
'75's Avatar
Easiest way I've found to get it off if you don't have a puller is turn the crank till the key is on top, get a chisel and place it between 2 sprocket teeth at the key way and give it a whack with a 2 lb hammer. The sprocket splits at the key way and you pull it off with your hand, takes about 30 seconds. Wont work with a quality sprocket, but works good on the stock type.
Old 01-24-2013, 07:37 PM
TedH
TedH's Avatar
Thanks all! Sure thankful for all the great feedback. I now know what I need to do with the front of the engine (crank gear and the damper) for my cam swap.
Outstanding!
Old 01-25-2013, 09:52 PM
tfi racing
tfi racing's Avatar
When its time to install your new gear,some heat is your friend.Warm it up in the toaster oven,heat gun or even sit it on top of your trouble lamp bulb for a bit,then slide it on with a slight tap or two.
To How Do I REMOVE My SB Crank Gear? Tool?
Quick Reply: How Do I REMOVE My SB Crank Gear? Tool?
