Corvette Forum
Go Back   Corvette Forum > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Register Forgot Password?
Register Vendors Buy a Vette Albums Search Today's Posts Mark Forums Read FAQ TSB & RecallsGarage
Search
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette Sponsored by
VBP
Welcome to Corvetteforum.com!
Welcome to Corvetteforum.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join Corvetteforum.com today!
Corvette Store
C6 Parts & Accessories
C5 Parts & Accessories
Wheels & Tires
Sponsored Ads
Vendor Directory
Old 01-20-2013, 05:48 PM   #1
Sleazy Rider
CF Senior Member
Sleazy Rider's Avatar
Default Zf 6-speed into 72 4-speed
I've seen threads on installing a T-56 into the C-3's but have not been able to find one for installing a ZF 6-speed out of a C4 Corvette into a C3 Corvette. Has this ever been done before, to anyones knowledge? If a T-56 will shoe horn into a C3, and the T-56 and the ZF are similar in size, and the ZF was the manual trans from 89 to 96, I would think someone did this conversion in the past. Parts is not an issue, I have 3 transmissions and 2 bellhousings to driveshafts for the conversion.
Thanks.
Sleazy Rider is offline   Reply With Quote
Old 01-20-2013, 07:54 PM   #2
CA-Legal-Vette
CF Senior Member
CA-Legal-Vette's Avatar
The only person that I've ever seen do this is TwinTurbo, who doesn't come to CF very often any more. As I recall the bell housing is different, which required modification, you needed a hydraulic clutch ( no big deal) but probably the biggest issue was that the shift lever was noticeably further back. Iirc, he moved the motor forward to mitigate this.
I also think that you'd have to significantly modify the tunnel on a C3. The ZF is a bit of a monster.
CA-Legal-Vette is offline   Reply With Quote
Old 01-22-2013, 09:40 PM   #3
Gale Banks 80'
CF Senior Member
The biggest issue with the ZF is the lack of aftermarket parts. It needs the Duel Mass stock style Clutch or the trans will rattle in newtral. But if You have all this stuff go for it. It will use a reverse pull Clutch stock but you may be able to use another Hyd pilot bearing if You wish. The stock ZF Bell housing will bolt right up. If You jump over to the C4 section there is probably a lot of info. Also go to ZF Doc.com for all kinds of info. Carolina Clutch is where to get a replacement, consider stage two as stock. My 96 GS with a B&M Ripper Shifter is the best shifting Trans I have ever driven.
Gale Banks 80' is offline   Reply With Quote
Old 01-22-2013, 10:07 PM   #4
qwank
CF Senior Member
qwank's Avatar
I put a clutch/flywheel in my brother's '93. We had to replace the flywheel because it was smoked. We had to go with a single mass because the GM dual mass is long discontinued. Even if you find one if would be a ton of money. (I think Rock auto had one for $1200) anyways, the rattling noise in neutral was so terrible that my brother got rid of the car. It's sounds like a lower end knock with your foot on the clutch in neutral.
qwank is offline   Reply With Quote
Reload this Page Zf 6-speed into 72 4-speed
Search this Thread:
Click for Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Friendly URLs by vBSEO 3.5.2
Emails & Password Backup
