Harmonic balancer size
Old 01-17-2013, 06:06 PM
VetteNURSE
VetteNURSE's Avatar
Default Harmonic balancer size
Does anyone know what size the harmonic balancer was in 1976 for the L48 and the L82?
Mike
Old 01-17-2013, 06:18 PM
7t9l82
7t9l82's Avatar
the L-82 used the large balancer 8 inch which was also used on the LT-1 and the 350/350. others used the smaller balancer
Old 01-17-2013, 08:00 PM
VetteNURSE
VetteNURSE's Avatar
Im curious as the the reason for the different sizes.
Old 01-17-2013, 08:55 PM
gcusmano74
gcusmano74's Avatar
The L82 engines used a forged steel crank designed for high RPM use. The larger balancer was used to control the vibrations at those higher speeds. Probably overkill on a street engine, but it had "image".
The base engines used a cast ductile iron crank, had a lower redline, and used the smaller, lighter balancer.
Old 01-17-2013, 10:45 PM
aussiejohn
aussiejohn's Avatar
Default Interesting..............
G'day,
No hijack intended, but I have a '74 L48 on which the outer ring of the HB has slipped. I bought an Australian built PowerBond HB which is 8" and plan to fit it shortly along with a new oil seal. I can't imagine that the bigger HB will have any ill effects on the engine, but by asking the question here, I know I'll get a well informed answer.
Thanks guys.
Regards from Down Under.
aussiejohn
Old 01-18-2013, 12:21 PM
George Ries
George Ries's Avatar
Seven inch on l48
Old 01-18-2013, 04:59 PM
Solid LT1
Solid LT1's Avatar
I think you will find 8" balancers on both motors just a thicker one on a L-82 application but, what the hell do I know............
Old 01-19-2013, 01:39 AM
George Ries
i just went out to the garage and measured the one i took off my 76 L48 it was seven inches im assuming it was the original one that came with the car
Old 01-21-2013, 01:01 AM
aussiejohn
aussiejohn's Avatar
Default Thank you.
Thanks mate, I knew you'd know the answer.
aussiejohn
To Harmonic balancer size
Quick Reply: Harmonic balancer size
